Question about Motorola Mobility RAZR V3
Boot loader message - Motorola Mobility RAZR V3
My phone does not operate. When I turn on my phone then the following message appears. Boot loader 03.02 SW Version R26111VL_U_96. AO.ODR Battery Low Cannot Program Please reply solution...
Try charging your phone.
If that doesn't help solve the issue, you might have a corrupt boot loader on your phone and you will need to take it in to your carrier's store / kiosk to get it replaced.
Mar 05, 2011 | Cell Phones
Boot Loader 03.E0
probably you had pressed the bootloader buttons.
once the phone is diplaying a status message like you are having, it means that the phone is ready to be flashed. if you haven't do anything to your phone after displaying the message, try to remove the battery and put it back on. but if you had this status message during flashing, it will give you the same issue even if you remove the battery.
take care.
Jan 14, 2010 | Motorola Mobility KRZR K1m Cellular Phone
Im getting the ntldr is missing message on my acer aspire 3100 that i just bought from a friend. I have no idea on how to fix this
That is the NT Loader in win98 was boot.ini regardless the OS will not continue without it. You can simply place your OS CD in set your boot order in bios to boot from cdrom. Do a manual windows repair. This will re-install the missing boot loader.
Dec 30, 2009 | Acer Aspire 3100 Notebook
Stuck on boot loader,phone code sig error v3i r47a_g_08_d8_89r''
I Charged the battery up using another motorola phone,and then I did a software upgrade, and this has fixed the problem.The phone is working great now,all photos or videos were saved.
What i think caused this error is that the phone was doing an upgrade and then I got a message at the same time,I think these clashed some how and prevented the upgrade from completing,hense causing an error on the boot loader.
Hope I helped
Chris
Dec 26, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Screen Message: Boot Loader....OK to Program USB
hold * and # and Power On when the phone is off..do this two times if first time not solves the problem. If you still have the problem it means the soft is broken and must be implemented again
Oct 29, 2009 | Motorola Mobility RAZR V3i Cellular Phone
When I Power up My Motorola Razr V3 I get boot loader message
At you the program has flied, the software loader therefore is loaded. You should program phone again. Programs are for this purpose necessary the driver, cable USB. Or give to repair.
http://heaters.agilityhoster.com/
Aug 09, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Windows vista ultimate will not boot up
Press enter and submit the changes :) computer should repair itself from a back up file and start as normal.
Regards
Jun 08, 2009 | Acer Aspire 3680 Laptop
System shut down on my v3x
is it working , after you charge? or only boot loader?
Apr 19, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
82 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
