Question about Refrigerators
I have the screws out of ice maker. Its hanging by plug what keeps it plugged in. I don't see a release point.
  • Thomas Garringer
    Thomas Garringer Jul 29, 2009
    We got it. Had to pry it open a little and the harness
    came right apart.
    Thanks to all.
    Scholar:
  • 117 Answers
To my knowlege there is no release point . Just need to wiggle till it is free. Hope this helps
Posted on Jul 28, 2009
  • Steve Darnell Jul 28, 2009
Model kfis29pbms02
Most have 3 each quarter inch nut driver screws that you have to loosen. One of them, the bottom one must be removed completely and slipped the ice maker upward until it comes off of the screws once off of the screws unplug the ice maker from the refrigerator do the replacement in reverse of what you just did. The plug has two little clips that you must squeeze to release the plug from male from female
Nov 20, 2015 | KitchenAid Refrigerators
How do i remove an ice maker from an admiral hmg 62184
Most have a multi-connector electrical plug and a couple of screws that the ice maker hangs on. Disconnect the connector (most squeeze somewhere) and then loosen the screws. You may have to stick your head inside to see them. The water just 'falls' into a trough and thence to the chiller.
Jul 23, 2014 | Refrigerators
How to make cubes fuller
You have to adjust ice thickness sensor it hangs in front of the evaporator at the top it will be white with a 5/16 screw going through it to increase the thickness of ice turn clockwise no more than a 1/8" at a time then let it make a batch of ice. carefuller you don"t want to make the ice to thick this would cause ice to hang up on evaporator plate and could damage it.
Jul 10, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
I have a new Continental ice maker - bought 2 years ago, but was plugged in for first time yesterday. Motor won't run. Added water to proper level. Plugged in. Set cube size. In one minute red water...
Check the water pump, I had the same problem, the water pump was bad but unable to find replacement parts at this point. The pump is a ZB-1200 made by Zhongboa Motor Factory,
Good Luck
May 09, 2011 | Continental PortableCE-IM65151 Ice Maker...
Ice maker control arm has broken and ice machine keeps making ice. How do I stop the icemaker? And, then, how do I fix or replace the control arm (which appears to have snapped at the point that the arm...
Good day,
You will have to remove the ice maker. Usually 2 screws or clips on top and one screw on the bottom, as well as the plug that supplies the electrical power.
Since you'll need a new arm anyway, I would suggest you take the ice maker to any decent sized appliance parts house, and see if they'll pull the the old stub out and install a new control arm.
If that doesn't work, you'll need to replace the whole ice maker.
If you want to see if you can remove the stub yourself, unsnap the front cover. You'll see a semi-solid state type board. It is held in with 3 screws. Remove those, pull the board off, and inspect the area we are talking about. You might be able to get it out, but if not, go back to my first suggestion.
Oct 11, 2010 | Amana ARB9059CS Bottom Freezer...
Ice maker quit working. I found water on the floor outside freezer side. This happened after a power outage and the ice maker hasnt worked since
The ice maker is freezing sound like it turning but not dumping and new water is comming in and no where to go except over the top. A new ice maker is around 100.00 Sears had them on sale recently for 49.00 find a used appliance store and maby pick one up for ten or fifteen dollars. You can install it the just plug in and hang by two screws.
Apr 26, 2010 | Kenmore 21.8 cu. ft. Side-By-Side...
Icemaker not working, the water despencer is ok, so i know there is water coming in ,it is in on position, no ice is stuck,what do i look for? next move
When the ice is frozen hard the ice maker has a heater that activates so the ice can be released, the a rotating mechanism rotates to push the ice out of the ice maker. Then cycle starts again by dispensing water in the tray. A lot of times the ice maker itself is defective and must be replaced. They are just attached by two screws and plugs into the freezer plug.
Feb 12, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do you remove the ice maker in side by side kenmore refrigerator, the kind with dispenser in the door. It won't turn to release the ice, and has a solid block of ice in it now.
Most ice makers hangs on the wall with three screws. two at the top and one at the bottom. Just loosen these screws and the ice maker will lift off the bracket and you can then reach the wiring harness to unplug it.
Sep 27, 2009 | Freezers
How to disconnect the plug on the ice maker of my Kitchen aid ref
Just use a butter knife and release the harness at the head. Get the end up against the tab and it will release easily.
Aug 23, 2009 | KitchenAid KSCS25FKSS Side by Side...
Refrigerator has an icemaker we never connected.
with Most The ice maker hangs on the wall with three screws. two at the top and one at the bottom. Just loosen these screws and the ice maker will lift off the bracket and you can then reach the wiring harness to unplug it.
Aug 14, 2009 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
