Question about Raritan KVM Drawer T1500 (Beige) 15 in. Flat Panel LCD Monitor
KMM display is dim and discolored when connected to PowerEdge 180AS. Problem disappears when 180AS console switch is bypassed. ???
When i start the computer the sreen on the top half of the monitor is discolored. how do i fix this?
Posted on Sep 13, 2009
Dell poweredge 6600 no display
If the "vga cable not working" then it is not "all componets connected correctly."
Nov 13, 2013 | Dell PowerEdge 6600...
Screen is blank when powered up and i cant see anything on the screen
Hello.
Connect an external monitor / display to your laptop to see if your laptop's display is faulty.
If faulty, it is the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim rather than a slow degradation, the inverter would be indicated.
In either case, a technician in your area should be able to help. Evaluate to see if the repair is cost-effective.
Hope this helps.
May 24, 2011 | Computers & Internet
Knob interior broke, spring fell out. How do I fix it?
Use quick steel putty to make a new connection for the switch. Tou can shape it and let it harden. Once it is hard sand to proper shape and fit.
Feb 17, 2011 | Braun KMM 30 Electric Burr Grinder
This lap top has no picture - the screen is black
Hello.
Connected a monitor to the laptop to see if the video card is faulty.
If an external monitor works, it is the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation the inverter would be indicated.
Hope this helps.
Jul 03, 2010 | Computers & Internet
Can I Connect both Poweredge 860 NICs to the same switch? It seems like they are setup to be redundant.
Yes, you can connect both NICs to the same switch. They each will have a unique IP address but will speed up your connection.
Good Luck
C2Solutions
Jul 02, 2010 | Dell PowerEdge 860 (becwnk1_7) Server
Screen very dim ..how do i turn up the contrast /brightness
Hello !
Test with an external monitor. If it works, there is a problem with the display's backlight or inverter board.
Hope this helps.
May 08, 2010 | Computers & Internet
I have a Toshiba Satellite A55-S1063 the scrren is dim but I can still see using a flashlight. I have had the back light replaced once it worked great for about 2 weeks and then went back to being very...
Hello !
Since the screen is dim, the display's inverter board needs to be replaced.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation, the inverter would be indicated.
Hope this helps.
Dec 01, 2009 | Toshiba Satellite A55-S1063 Notebook
When I turn on the headlamps the dash lights go out. Guages all work, radio display disappears also. fuse is good and tried changing headlight switch
Get a test light,and ground the clip,put the tip of the test light on the dash light fuse.Turn the knob to dim,and brighten the dash lights,see if the test light reacts with the dimmer switch.If it does not,then there is a wire jumped to by pass the dash lights somewhere.If the test light dims,and brightens,then there is a wire of going to the dash,or bad connection where the harness clips into the dash.
Oct 28, 2009 | 1989 Ford F 150
Sudden lost of color gamma - "discoloration"
GO ON LINE AND SEE IF ANYONE ELSE HAS BEEN HAVING THE SAME OR SIMERLY PROBLEMS OR MAYBE A RECALL ON THAT CERTAIN ITEM.
ADDRESS BAR:
BENQ G2110W GAMMA ISSUES,
GAMMA FAILURE,
LOST GAMMA.
ENTER...................... AFTER EACH COMA
ANYTYPE OF PROBLEMS WITH BENQ G2110W
ENTER
GO ON TO ABOUT.COM, ASK.COM, INFO.COM
ROD
Feb 17, 2009 | BenQ G2110W 21" Monitor
PS3 video output on SD tv is wavy with discoloration and black line
when you switch the ps3 on if you hold down the power button for more than 4 seconds it runs the display setup. and sets the ps3 to run in the best possible option
Dec 25, 2007 | Sony Playstation 3 (PS3) Console
Raritan KVM Drawer T1500 (Beige) 15 in. Flat Panel LCD Monitor Logo
209 people viewed this question
Top Raritan Computers & Internet Experts
Mike
Are you a Raritan Computer and Internet Expert? Answer questions, earn points and help others
