Question about Kenmore 400 6942 Dryer
Dryer timer is not working - Kenmore 400 6942 Dryer
  • 6,784 Answers
HI, the timer mech is not repairable. you will need to replace the entire device if found to be defective. usually, the motor will become unstable, in return, not allowing the timer dial to advance. replace this damaged timer asap, if possible.
Posted on Jul 27, 2009
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
I have a maytag dryer mdg 6460aww. timer is not working I I exchanged-timer. , temp switch, cycling th'st, high limit th.st My question is why does not operate on a timer
It's none of the above. The part your dryer requires is the dryness control board part #33002905. Unfortunately they are NLA. If you are really good, you can study the wiring diagram, unplug the board from the system and send power directly to the timer from the motor to run the timer when the unit is running. This will only work properly for the timed dry selection as the dryness sensing is eliminated.
Beats replacing the dryer and the part MAY be remanufactured by Whirlpool. So it might be available in the near future.
May 01, 2014 | Maytag Atlantis MDG8400AW Gas Dryer
Dryer timer not advancing
If the dryer is working fine and the timer does not advance, then the timer motor has gone out and you will need to replace the timer. Here is the part to order.
Nov 04, 2012 | Dryers
My kenmore dryer just stopped working. the timer
the timer has internal cog teeth with works with an ecentric cam to keep the timer operating. the cam is working if ticking although a tooth appears to be broken keeping the timer to advance on its own
Mar 13, 2010 | Kenmore 63942 Dryer
The timer doesn't work. The dryer just runs until
is the heat working?when the dryer heats up and then the heat will shut off then the timer advances,when the heat turns back on the timer stops,heat shuts off the timer will move again,if the heat is working you could have a bad timer
Mar 12, 2010 | Frigidaire GLER341A Electric Dryer
Hotpointdryer timer problem
There are two coils in the heating element, and if one burns out, the timer will not advance in automatic dry. The timer should still advance when using manual (or timed) dry.
Jan 20, 2010 | GE DBSR453EBWW Electric Dryer
My dryer works ...tumbles ...heat works...timer stay where you put it when you start it..maytag dependable care plus dryer
Your timer motor is bad. It is very similar to a clock motor and it drives the timer on your dryer.
Oct 08, 2009 | Maytag Dryers
Replaced timer module. Dryer did not run.
Check the voltage across the timer motor, make sure that you have 120 volts. If you have 120 across the timer motor, then it is bad. Also check your wiring to make sure you have wires in right place
May 01, 2009 | Maytag Atlantis MDG8400AW Gas Dryer
I have a roper gas dryer. The Timer stopped
my roper just stopped working this morning the timmer nor the heater or the dryer itself will not at all.
Apr 04, 2009 | Roper RGX4634KQ Gas Dryer
Timer motor keeps running on dryer
sometimes as a timer gets older the timer motor will get a little loud. timer motors run even when the door is open. if the timer advances to off and everything works fine you don't need to worry about it.
Nov 19, 2008 | Dryers
Kenmore 400 6942 Dryer Logo
281 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
