Question about Grilling
What goes in the power hole on the side of the grill
    Top Expert:
  • 24,726 Answers
Make and model may help you get an answer.
Posted on Aug 19, 2017
Im in need of a wiring diagram for a Kenmore Side by Side refrigerator Model # 10657075791
The schematic should be under the kick plate grill. Remove grill and should either be in the grille or behind. Defrost thermostat is located on top of the evaporator behind back panel inside freezer
Dec 14, 2014 | Kenmore Side by Side Refrigerator
How do i attach toe grille?
Hi Debby. I presume you're referring to the grille across the bottom front of the fridge? Based on several different brands of newer fridges we've owned, they are often held in place by spring clips that fit into matching holes at the bottom of the fridge frame. Gently push the grille into its proper place, using your hands over the parts of the grille behind which the clips are located, ensuring the spring clips are aligned with the holes they go in. The spring clips will "snap" into place and hold the grille there. If clips are aligned with holes but grille isn't snapping into place, I push harder on grille with my palm over only 1 end at a time (as close to clip location as possible). Most grilles being plastic these days, use the minimum force possible to get grille back into place, remembering some need more "encouragement" than others (due to rusty clips/frame holes, extremely strong clips, etc.).
An older fridge (going on 20 years) had the grille held in place by a spring attached to each end of the back of the grille. My experience was that the grille never came completely off; it was only moveable. If a spring breaks (metal fatigue), or is disconnected from fridge frame and not re-attached, the grille may "sag" on that end, requiring a new spring (or re-attachment) or a piece of wire to hold it in place.
Feb 27, 2012 | Frigidaire Gallery GLHS66EJSB Stainless...
How or where do we reinstall the rotary igniter electrode. Can't figure out where it fell out of.
there should be three holes together, the center hole being larger than the two side holes. The shaft of the igniter goes through the larger center hole, and the screws to attach the igniter go through the smaller outside holes.
Jul 04, 2011 | Sunbeam Grill Series 760
How do i install the rotisserie on my is a pro series 8534...there are no pre-drilled holes and there is no way of closing the lid on the pit while it is cooking,,there is a slot cut out on the...
Buy the Brinkmann Universal Rotisserie Kit model #812-7102-S for $49.95. It uses 2 screws to attach a bracket to the existing tapped holes in the grill. It was that easy! I purchased my grill and the Rotisserie at Home Depot.
Oct 18, 2017 | Brinkmann Grilling
Weber genesis S 320: Most BBQs have a hole in the side to run the propane line from the tank in the cart to the burner insert. The side panels on this seem to have no hole. Perhaps a small space right at...
Your correct. As looking at it, the right side panel has a hole just larger in Dia than the Regulator to fit thru. Feed it through to the inside of your cabinet and connect. There is also a Propane indicator that I haven't hooked up yet. Enjoy.
Aug 31, 2010 | Weber Genesis S-320 Propane Grill
Need rubber foot for frigidaire professional series gas stove iron grill. My stove has three grills, each grill having 4 rubber (rivit-looking) feet. Apparently the missing foot, as small as it is,...
I just had my stove serviced today. You can purchase a foot kit for $30. The part # is 5304475129. I could not find a place that only sold the rubber feet. Clean any debris from the hole that the rubber feet goes into. Add a small amount of the high temperature adhesive in the hole. Insert the rubber feet back in. The rubber feet has a pin point hole in the middle. Insert a paperclip in the hole and stretch out the sides of the rubber feet, so the sides stick to the adhesive. Place the grates back onto the stove and let it sit for 2 hours. Good luck.
Feb 06, 2010 | Kitchen Ranges
Gas Grill Burners with yellow flames coming from beneath them
the flames should be blue and the burners clean. check gas pressure and the air mixture dampers. touch air will give you the same effect. if the burners are clean, it is the mixture. as far as the slots in the bottom. i have not seen that. but i work on commercial ranges.
Feb 27, 2017 | Char-Broil Commercial Stainless Steel...
One burner on the Ducane gas grill lights only weakly. Gas is coming through but only some of the holes ignite. The other side is uniformly lit, but the flame only goes maybe 1/4" high. Clues?
try opening the tank really slowly. the tank has an overfill protection devise built inside and if it is opened too quickly it can restrict the gas flow to the burners. hope this helps.
Sep 14, 2009 | Ducane Grilling
Grilling Logo
204 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
