Question about Averatec 3200 Notebook
Can't find the wireless switch
Thinking that is at least the start of my inability to connect
  • 344 Answers
There is a round button just above the F4 key on the keyboard which turns it on or off, the one to the left of the power button.
Posted on Jul 27, 2009
  • 74 Answers
Look for an aerial symbol or something like i))), these will be above the usual key symbol on your keyboard in a different colour, you will have to use the shift or function key to activate it, some laptops have an actual switch, usually a slider, have a good look around your laptop to find it, also there should be a light that comes on once activated.
Once you activate it you will need your WEP/ WPA key and your SSID (router name) (providing your network is secure), otherwise if not secured the router name will appear in your available networks and you will be able to connect.
good luck!!
I hav a zoostorm kangaroo vme series laptop, the magnetic strip has stopped working and i cannot find how to connect my computer to my modem, is there another way of **** this??
Hi,try to update your windows and latest driver for your wireless lan or reinstalling the windows with your recovery DVDs,if you still have problem make sure your hardware is survive(think you drop the laptop or in water or use in bad humidity weather or not)
look at your wireless lan connection that you can connect to any other access point or not,
if you can connect but not go online problem is with your access point or wireless lan connection configurations(like IP address ,MAC address restrictions or DHCP PROBLEM)if so ask from some expert
if you can not connect to to any other wireless access point so you may have problem as i mention above in first step,
kind regards
Apr 17, 2013 | Computers & Internet
My son took out the dvd drive on my compaq presario s4010cl and i think he rehooked up the internal card wires wrong for the internet. It shows that i am connected but i can't actual get into the...
This is the schematic for the board in your HP machine
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=bph07845&lc=en#N837
This is a very old board, there should be no wires to the motherboard for the LAN or wireless, as the LAN connection is built into the rear of the board, any wireless connection will be via a PCI card, which plugs directly into one PCI slot.
I think therefore that the inability to get onto the internet is not the fault of your son, but a problem with the router security. Try disabling windows firewall temporarily and see if that helps, if not, please repost and describe the problem in more detail, including the model and make of your router
Aug 16, 2011 | Computers & Internet
Lap top will not conect to the wireless internet connection
If you are on a laptop: (windows)
1. check to make sure your physical on off switch for the wireless card is turned on. Windows will sometimes still show it as being active while the switch is physically still off.
2. Disable/re inable the software connection to the wi fi
(MAC) Disable reinable the wireless card in dropdown menu
3. restart the wi fi router
Jan 16, 2011 | WiFlyer - Portable, shareable WiFi base...
My c-series fujitsu wireless enabled lifebook is not able to connect to local wireless networks. i checked with the troubleshooter and everything is working, when i try to view available wireless networks,...
Now you just need to access the network gate address at your Fujitsu C2340 LifeBook C Series Notebook ,and open the wireless network function of the router.If you can't access in,it may be request a password,if you din't remenber,ask you friend how did he enter to the page.
May 31, 2010 | Fujitsu LifeBook C2340 Notebook
Can not enable wireless
Usually if there is a problem with the hardware it shows up wth a differant error. Usually disabled means it is switched off or you have the cable plugged in.
On a laptop we have the often annoying option of switching the wireless off to save the battery. On your model the off/on switch or button is located just above the keyboard. There should be three buttons near the bottom of the screen. The left most button is the one we want. Just push it and your wifi should start if this is how it was turned off.
If it doesn't then we may need to check the network connections window. moz-screenshot.png moz-screenshot-1.pngHere we can make sure it is enabled. Unplug the cable connection if its plugged in. Some drivers will auto switch to the faster speed ie the cable while others go to the wireless. Unplugging it forces it to try the wireless.
Click on start then look for something called network connection along the right side. If it is there then click on it and it will bring up a window called network connections. You may have to go to settings then control panel and network connections which is the other way of getting here.
This should show 3 things. A cable connection ie something like Broadcom 10/100, your wireless connection called something like Athero's and usually something called 1394 which is Firewire. Right click on the wireless one and if it says ENABLE click that and your wireless should startup.
May 04, 2010 | HP Business Notebook 550
Limited or No Conectivity.
you might have two problems here (router and computer). test first your router if other computer can connect to it without experiencing similar issues. if other computer computers can connect to the router then there is no problem with your router.main problem would be your laptop. the mini troubleshooting will right actually but its very tedious if you will be doing that everyday. what you will do there is to reinstall your wireless adapter driver. usually driver cd is included in the system when you purchased it. if same thing happened after driver installation then there should be a problem in your wireless network card. you can test it by going to command prompt and type in ipconfig once you saw this Limited or no connectivity error. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router.
Apr 07, 2010 | Microsoft Windows XP Home Edition
Dont know how to turn on the wireless to my ibm think pad t40
BODY { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } P { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } DIV { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } TD { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } Some systems come with a Wireless Radio switch to disable the wireless radios. The wireless radio switch is usually located on the front side of the machine. If you are having difficulties with wireless connections, make sure the Wireless Radio switch is set in the On position.moz-screenshot.jpg0d7fbfc.gif
Jun 08, 2009 | IBM ThinkPad T30 2366 Notebook
Sudden inability to connect
Try to renew your IP address
Start >> Run >> type ....cmd >> one black screen appears.........type...... ipconfig /renew
And try to get the internet again
Oct 29, 2008 | Belkin (F5D7230-4) Router (587009)
Unable to connect the internet with wireless!
delete wireless connections and reboot,insure you do not have the wired ehternet cable also installed, and insure that wireless switch is off as well for now. when system reboots, turn on the wireless switch and see if the program for IP is corrected.
Jun 16, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Averatec 3200 Notebook Logo
90 people viewed this question
Top Averatec Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
