Was clothes did not checked my poctkets diamond necklace is it wash down the drain or what
    Scholar:
  • 70 Answers
Depends
But to try all measures to retrieve your jewelry immediately disallow anymore use of the machine so you can check everything.
1st check the machines drain tube. { remove it and turn it upside down }
Inspect the opening hole where the drain tube was affixed to look into and feel inside for the jewelry.
Have the machines tub physically lifted up and out to see if your jewelry slipped through irrigation holes.
Lastly place a screen over the drain and run a clear water cycle through the machine to see if it flushes your jewelry out.
Posted on Jul 27, 2009
How Can I Melt Old Gold Jewelry Down At Home?
Compound cleaning agents must be eliminated as is also known to affect an article of knickknack. You can simply clear your necklaces with a sharpening fabric. Bracelets is really a kindof associated with purchase for this reason picking a reputable supplier is critical. Obtaining necklaces of the most useful guarantees one of outstanding workmanship and excellent produce. It's not necassary to leap to the variety right away somewhat spend time on correct evaluation involving high quality and simply get you now are totally delighted by the fitness of the cheap diamond jewelry online.
Aug 31, 2013 | Watches
I have a Maytag MAV6200AWW Atlantis Washer. A necklace got caught in one of the bottom holes of the plastic tub - It must be knotted on the other side, as I can not pull it through. I do not want to break...
There is no "simple" way. Under the part with the holes is the tub without holes that holds the water in. If the neclace breaks it will go to the drain pump and most likely be blown out the drain. However you can try putting a few drops of vegetable oil on the necklace allowing it to go down below, and wiggle it around in an effort to untangle it.
Nov 10, 2010 | Maytag Washing Machines
I have a samsung 13kg diamond drum toploader, my problem is after selecting all relevent options to wash my clothes when the machine start washing the clothes it also drain some water out. My clothes end...
If the drain hose is pushed too far down the drain pipe, it will have a tendency to to siphon out. Only use 1 or 2 table spoons of detergent as the washer uses very little amounts of water. Read your instruction manual as it says the drain hose has to be higher than a certain height before it goes to the drain.
Oct 16, 2010 | Washing Machines
My diamond necklace fell into my heater vents. I was able grab the chain in time but the diamond fell down into the vent. How do I get into the dash AND the heater vents to retrieve my diamond?
A Ford dealer might be able to help you. The vent heat and air goes down to the air heater, it you take that loose the diamound might just fall out.
Sep 10, 2010 | 2005 Ford Ranger
My daughter's necklace is stuck in the drum of my bosch nexxt 500 washer
the drum may have to be removed and taken apart in order to get the necklace out.or the chain may have to be broken and the rest ran down to the drain pump for removal
May 18, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
The washer seems to deposit stains on the clothes. No amount of stain remover seems to remove the stains.
just a though check inside the washer for things like paperclips,thumbtacks small pieces necklaces things like that get caught in those small drain holes and cause havoc
Apr 13, 2010 | Electrolux EW1000i Front Load Washer
I think my daughter left necklace in laundry. I
Unfortunately there is no filter for these. You might get lucky and be able to remove one of the drum paddles inside the tub, and on some models there is a hole where you can see between teh tubs. Even then it'll be pure luck if the necklace is in the right place. Otherwise, it's just a matter of waiting until it goes into the pump, and likely jams it and needs to be removed.
Apr 03, 2010 | Frigidaire ATF6000ES Front Load Washer
Diamond ring went through wash cycle
If there is no filter to be seen at the fron t of washer, then remove the rear cover, locate the large blkck hose fastened to bottom of drum, remove and check inside the hose, there is a good chance the ring could be trapped in the hose.
Good luck.
Feb 11, 2010 | Washing Machines
Water is not draining out of kenmore 11020802990 washing machine
http://repair2000.com/demo_pump.htm
This will redirect you to a site to check and see if your drain pump is not functioning correctly. I would be willing to bet that therein lies your problem. Quite usually the pump itself runs fine however there is debris inside that will cause the pump not to function correctly. I. E. Dirt, Lint, heck I've even found a diamond necklace that had been lost that way.
Other things you can check without tearing the case off is to make sure that the hose is not kinked or clogged. I've seen sometimes where hair will get caught up in there as well.
Jul 29, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Daughters necklace caught in washing bin holes
If you cut the chain what is left could possible work its way into drain pump. Jamming it.
Jul 20, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
