SOURCE: I need instructions on removing the front housing
Hi again Guy, It is easy to overlook the obvious, I do it a lot. There are two allen screws in the rubber boot at the front bottom that need to be removed to release the foot (or shoe), which should slide out the end. Then the whole boot ( forward hand grip) pulls off the end exposing the assembly you need to replace. Good Luck to you, this should Fixya!
SOURCE: Disassembling hitachi 18v reciprocating saw
In addition to the 8 obvious bolts there are 4 more under the gearcase insulator holding the gearcase to the housing. I looked at a schematic for the 18V recip saw and that is all I saw. Have you tried the Hitachipowertools.com website for the schematic? Let me know if you still have trouble.
SOURCE: I need a parts diagram
go to "managemyhome.com" and under manuals type in your model number and you can download the manual with parts explosion towards the back. The manual is 18 pages long. If I have helped you you with your request would you please vote accordingly and thank you
SOURCE: We have a ryobi rj150v model reciprocating saw
There are 2 types of clamps that hold the blade in that type of saw.
Since this is an older one it most likely has the type where the blade is held in place with a set screw and a "U" shaped piece of metal that holds the blade tight against the shaft. There should be a screw hole in the shaft of the saw. The blade rest next to the shaft and then the metal piece clamps the blade against the shaft. This is all held in place by a set screw that screws into the shaft. This screw uses a hex key to remove and tighten it.
If your tool doesn't have this style then it should have a twisting clamp. This will rotate and release the blade. Sometimes a pliers is needed to loosen the collar, but not to tight tho.
