Question about Kenmore Elite HE4 Electric Dryer
Wonderful sound, no picture
I plugged in the tv yesterday and it was working fine. This morning I went to watch some tv an all I got was sound. Nothing comes on the screen at all... not even a flicker or lines. Is it a hopeless cause?
I have a JVC model HD-52G886 tv. that loses sound.
Replace or have replaced the Audio board in the set----a lot of them fail.
Mar 12, 2012 | JVC HD-52G786 52" Rear Projection HDTV
There is no sound coming through on HD channels, it has been working fine with no problems but woke up yesterday morning and it no longer works. we can watch tv with sound through the normal scart but...
What TV model is it?
You should begin by unpluging the TV from the mains and have the TV unpluged for at least 3 minutes, if that does not work then you need to factory reset the TV, but note that you will loose all of your previous settings on the TV.
I hope this solve your problem.
Jan 02, 2011 | Televison & Video
No power. Died when turning on to watch TV.
unplug for a couple of minutes then plug back in and try
Oct 29, 2009 | Niko SV3206 32 in. LCD Television
Screen goes blank while watching
Couple of things:
1) When the picture "stops", does the standby light blink at all?
2) Can you post the model number please?
Some of these sets are known to have problems with the picture tube as it starts to age. There are some workarounds for this that can extend the life of the set for a short time. Without the model number though, I can't confirm that this set is in that catagory. Please supply responses to the issues above and we'll continue from there.
Thanks,
Dan
Sep 22, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sound but no picture
It's most probable that your lamp is busted, since the tv didn't went out completely. Replace the lamp and you'll be fine :)
Sep 01, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Rca 32flascreen tv
high volatge transformer shorted...or component in hi E.
Jul 18, 2008 | RCA F32450 32" TV
No sound when watching freeview on Samsung 32" LCD TV
I`ve got the same problem, sound with analog but not digital?
Dec 12, 2007 | Televison & Video
No picture but sound works.....
  • adjust brightness setting when playing tv.
  • adjust screen control located on flyback transformer.
  • hope this will help.
Oct 23, 2007 | Sony KV-36FS16 36" TV
No sound on my 8year old panasonic tv.
It worked fine yesterday. Sound on all channels. Sometimes the picture goes black on channel 6. We can get it back by going up one channel, then back to 6. it is due to cable signal ie weak. now there is no sound this is due to sound section 1 loose connect in sound section 2 speaker 3 problem in sound section some part must have failed.
Sep 17, 2007 | Panasonic CT-32SX12 32" TV
Kenmore Elite HE4 Electric Dryer Logo
46 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
