SOURCE: 1968 ami rowe mm-2 juke box
the button may be repaired i suppose.. you need to replace with a new one else sontact a service center.. u stop pressing it and replace it.. if it goes on running it may create a master problem.. so first change the button!!
chek tis out
http://tomszone.com/serialami.html
else
look out
http://www.gameroomantiques.com/Manual.htm#AMI-ROWEJUKEBOXES
SOURCE: juke box will take coins but won't play record
WHAT IS THE POSITION OF THE GRIPPER ARM(CALLED GRIPPER ARM THAT GRABS RECORD?)
OVER THE TOP OF THE 50 RECORDS? NEAR THE TURN TABLE?
IS THE OPERATE SWITCH IN PLAY POSITION ? OFF POSITION ?
DOCTOR FIX.
SOURCE: juke box (seeburg 480 serieswill take coins but won't play record
YOU ARE SAYING THE MOTOR DOES NOT SPIN. TRY TO SPIN THE DRIVE SHAFT ON TOP OF MOTOR . DOES THE SHAFT TURN EASY. IF NO THEN YOU HAVE A MOTOR OR LUBRICATION.
PROBLEM.
DOES THE SCAN SWITCH, WHEN PUSHED TO SCAN DOES IT SCAN. IF IT SCANS BACK, AND FORTH 2 TIMES, YOU THEN HAVE A COIN CREDIT PROBLEM (MOST LIKELY )
ANSWER THE TWO QUESTION, OR STATEMENT. TO GET A MORE INTELLIGENT REPLY.
YOU HAVE OVER 2000 PARTS IN THAT MACHINE. YOU HAVE GIVEN A (WHY DONT IT WORK
QUESTION.)( there is no answer to the question. because of limited problem info)
DOCTOR FIX
IN-HOME JUKEBOX REPAIR
6362273300
SOURCE: my rowe ami cd100 plays but there is no bass only
Hi Tony,
More than likely it will be an amplifier problem, but check that the phono leads from the mechanism decoder are ok and that there are not any dry joints (cold joints in the USA) on the phono connections on the decoder.
Check that the amplifier does not have any dry joints on the connections between the input and output stages on the amplifier.
If you are in the USA and need a repair send your amplifier to Bruce Wentworth (check for his details on Google) in the uk you could send me your amp for repair.
Regards
Alan Hood
ami-man
UK
[email protected]
