SOURCE: Sharp Carousel Microwave door latch stopped working door won't stay closed
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have *critical* safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
We also have this full service manual at our site: http://www.microwavedisplay.com/R1480_R1481_R1482_sm.pdf
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: LG LRFC25750 Refrigerator French Door
Freezer section evaporator fan motor bearing are going out. This would be indicted by a high pitched squealing noise. Have the fan motor replaced and it should solve your problem.
SOURCE: BEEPING NOISE
in the back of the fridge there is a panel. Remove the cover plate. Look for the buzzer and remove it. This will cancel the annoying beeping noise.
SOURCE: LG Fridge door constantly beeping when closed
On the display panel press the right key that turns the door alarm on and off
SOURCE: E522BLMFD model refrigerator door alarm
The door switch has 3 terminals and wires on it. Jumper the wire that does NOT turn on the light to the wire that is on C of the door switch. If you look at the switch it will have one wire distant from the other 2.... that wire is the power wire "C". You jumper that to the wire that would be attached to the "NO" terminal. After you jumper the wire... and TAPE IT with electrical tape the door alarm should be silenced and the internal light will NOT work until you replace the switch. Label the remaining wire with masking tape... NC and Actually label all 3 wires as you remove them... C, NC and NO. Just use write that on a strip of masking tape and then put it on like a horseshoe pennant.
You can order a switch from Fisher and Paykel AU. (See number below)
Phone
Contact our spare parts team on 1300 650 585
If your not in AU the door switch is very common... call any LOCAL appliance parts source and they should have one.
Thanks for choosing FixYa,
Kelly
