Televison & Video Logo
J
John Mehlem Posted on Aug 18, 2017
How do I replace the front panel? the buttons sink in when i am using
2helpful
4answers
Power button broke gfdn240el1ww
There are two main pieces to the front panel for the GFDN240EL1WW dryer-- the plastic panel and the circuit board. The actual replacement part is: Control Panel WE19M1687. The panel can be purchased for from places like partselect.com or repairclinic.com or Amazon or even EBay, etc. for $100-$200+.
The power button is just a piece of plastic mounted to another piece of plastic; it is not electronic. When pushed, it presses against the circuit board, which then turns the unit on/off. When the power button breaks, it typically means the little plastic button has broken off from the plastic panel. Most likely, the problem is the mount point for the button and the button is actually re-usable.
A cheaper quick-fix is to:
  • Remove top screw from back of the front panel
  • Remove main front knob from the panel
  • Remove screw from behind the front knob
  • Grab both sides of the front panel and push/pull up to remove the panel
  • Disconnect the block connector (power) from the circuit board after removing the panel
  • Locate the power button and mounting position
  • Inspect to see if it looks like you can glue the button back into place
  • Buy a small tube of loctite Stik'n Seal Ultra Universal Adhesive
  • Put some Stik'n Seal on the button mounting point for the power button (be generous)
  • Press the button onto the mounting point and hold for a few minutes
  • Add more Stik'n Seal around the edges of the mounting point and the button mount after you have held the button in place long enough so that it sticks
  • Let the whole thing dry for several hours (instructions on the adhesive say 24hrs
  • If you are worried about the button staying seated while the adhesive sets, you can always try tape it into place
  • When dry, replace the front panel by reversing the steps above used to remove the panel: connect the power block, slide the panel back into place, replace the front screw and knob, replace the top screw in the back of the panel
How to cover gap at back of kitchen sink cut out that sink rim will not cover up
You can use a schlueter T molding for tile in a stainless finish. Cut the T Molding to the length of the gap, - silicone the area and place, and put some weight on it to hold it in place until the silicone hardens. You can get the molding at a tile store, or big box store
2helpful
Will only perform a duvet wash and keeps beeping
your fault can be caused by the switches on the control panel sticking due to the fact the panel is not totally waterproof water from the sink in the kitchen can find its way into the panel it then corrodes the switches on the panel because the duvet button is at the bottom of the panel it collects water here making the switch stick. if you are able to remove the control panel yourself then you will be able to get an electronics engineer to fit a replacement switch.if not a call to dyson to repair and test your machine is the best solution
1helpful
Won't pump the water out. I checked the hoses and they seem ok. Itt doesn't seem to want to go into the pump out stage? When I hit the cancel button it pumps out but with ver little pressure
It sounds like one of two possibilities here.
The most likely is a blockage somewhere between the drain pump and the drain in the house (under the sink).
Places to look for this would be an air gap or the fitting where the drain hose connects to the house plumbing. Take the drain hose from the dishwasher off of the house pipe under the sink, run that hose into a bucket and see how it drains then. If it is poor then follow back toward the dishwasher until you find the next junction or fitting. If you are sure all these are clear and still not draining, you will most likely need a new drain pump, the part number for the pump is 661662 and runs about $70.00. It is right up front a bit to the right when you take the front toe panel off, it is pretty easy to replace
9helpful
Replace button on pull-out sprayer
With your faucet in the off position pull the sprayer out. Unscrew the hose that connects to the sprayer. This lets you take the sprayer to someplace where you can sit down. The front of the sprayer where the water comes out unscrews as well. You may need to use a nonslip mat or a piece of rubber but you can undo this by hand. Once you have this off a small piece (airator) can come out that helps control water flow into a steady stream instead of the way water comes out of a garden hose with no nozzle. form here you'll be able to see how the old button fits into the sprayer, pop it out and replace with the new one. Assemble in reverse.
3helpful
2answers
Hi, we just moved the tv from one room to another and now the images are just greens and blues. We lost the colors! What can i do?
Sounds like you have bad solder connections at your convergence ic's.These are large amplifier ic's mounted on large heat sinks.These ic's run very hot and can cause faulty connections at the solder joints.Try resoldering ,if this doesn't fix it you will need to replace them and any surrounding resistors that have opened.
1helpful
2answers
Dell 5150c shuts down orange flashing light
As a temporary measure, taking the side panel off the dell 5150c stopped it from shutting down, so in my case it was clearly a heat problem, as suggested by previous the poster. The following instructions assume you're comfortable replacing computer hardware components - do at your own risk!
The solution is to buy an 'air duster' and some thermal compound for the CPU heat sink. If your CPU fan doesn't sound healthy (mine didn't), also buy a new one (ca. £20 on ebay: search for G9474 ).
Read the service manual: http://support.dell.com/support/edocs/systems/dim5150C/en/sm/index.htm for details on how to install / remove the fan and heat sink.
Clean out dust from the heat sink with air duster. Remove the fan, and clean or replace (recommended). Also clean the grill in front of the fan. Clean off old thermal compound from the CPU / heat sink and replace with a thin layer of fresh compound. Replace heat sink and side panel and you're done.
Screen went black
Remove the front grey bottom panel of you TV (don't forget the 2 screws behind the front AV cover located just below the power button) then remove the panel behind the grey panel. You should see 2 heat sinks on the front right of your TV, place a fan near your TV and have it blowing on the heat sinks. Now turn on your TV and see if it stays on longer then it has been. If it does, your DC amps might be overheating. If they are, you might be able to fix your problem by adding in a little more heat sink compound between your DC amps and the heat sink itself. You can find the compound at Radio Shack for about $5. let me know if pointing a fan directly on the heat sinks helps.
1helpful
The dishwasher is not emptying out the water. It needs to reset and finsh the last cycle. Hotpoint DWF 33
pump under bottom front panel might be clogged remove hose clap from pump,cleanout,also can use shop vac.,also remove lower spray arm then remove filter clean and replace,also check under sink make sure drain hose is not kinked,thanks-mike
May 27, 2008 • Dishwashers
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
