Question about Xerox Phaser 6300DN Laser Printer
My Phaser 6300DN control panel is blank . Earlier it sometimes was garbled. Can I buy a new one? It seems the installation is easy.
    Director Badge:
    Uploaded 100 video answers.
  • 160 Answers
Yeah, you need a new control panel. Here is a video to help replace it and where to find it. Good Luck!
Posted on Feb 03, 2011
  • 724 Answers
You are pulling your own purse strings
Posted on Jul 28, 2009
Printer all of a sudden stopped printing, (LED screen out so unable to read errors). Everything was working fine and then it just stopped printing any more jobs, the red light was on the control panel and...
The inverted, blank, or garbled display is pretty common, a new control panel will fix that and is super easy to install and no tools required. Here is a video that shows how.">
Jul 04, 2010 | Xerox Phaser 8550DP Printer
The text on the printer's display shows up backwards, upside down, and when you scroll thru it, things get all cluttered. The printer operates just fine, its just impossible to scroll thru the menus on...
If your 6360 has a blank display, garbled characters, inverted, upside down, or backwards display the control panel is bad and must be replaced.
Here's a video to replace it. It's very easy and takes about a minute.
Apr 30, 2010 | Xerox Phaser 6360 Laser Printer
Xerox Phaser 6300DN is printing light black on right side of paper, replaced toner, transfer unit, imager with no luck
The laser window probably has either some toner or dust on it and needs to be cleaned. It will be under a shutter located in line with the drum.
It is less than 1/2 inch high and about 6 or 7 inches wide.
Clean that and your problem will go away.
Mar 25, 2010 | Xerox Phaser 6300DN Laser Printer
My xerox phaser 6300 control panel is blank and was working
Your control panel is bad and needs to be replaced, here is a video to show you how.
and here is the part (click here)
Mar 15, 2010 | Xerox Phaser 6300DN Laser Printer
How to install the phaser 6300 control panel
  1. Get a small flat head screw driver
  2. jam it on the bottom crack of the control panel and the machine then gently force the screw driver down and the control panel should pop up and it should come out.
  3. Then disconnect the harness and then connect the new control panel and just line up the holes with the plastic of the control panel and your finish
Good luck
Nov 24, 2009 | Xerox Phaser 6300DN Laser Printer
Xerox Phaser 6350 Control Panel display problem
If your display has a blank display, displays garbled characters, or the display is inverted or upside down, check out this video
Sep 10, 2009 | Xerox Phaser 6350/YDT Laser Printer
Xerox 6360 control panel blank
If your Xerox Phaser 6360 has either garbled characters, inverted or upside down display, or no display, the control panel is most likely bad and must be replaced. Here's a video on how to do it and where to get it. Hope it helps!
Mar 30, 2009 | Xerox Phaser 6360 Laser Printer
Xerox Phaser 8550dt printer
That is a known problem with the 8500 phaser family.
Contact Xerox at 1-800-835-6100, They WILL replace it for free. It is a known problem.
I really believe that display is failing. very common problem.
Just tell them the display is blank when you call. But they are faulty. Very faulty.
Sep 21, 2008 | Xerox Phaser 8500/DN Printer
The display panel needs to be replaced. The part number is 802K93650. We sell them for $160 plus shipping. Our number is 574-243-1176 if we can help.
Jul 23, 2008 | Xerox Phaser 8500/DN Printer
Display on Xerox Phaser 6350 not working unable to network printer
Defective Control Panel. In early 2006 a defect was found with some of the Phaser Control Panels. This has been corrected in manufacturing and new versions of the control panel placed into inventory. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Try the Engine Only test print on the rear of the machine. If the print is successful, the display is defective and needs to be replaced. Using the Centerware IS (CWIS) and using the Support Tab will connect you to Knowledgebase for any procedures on how to change this control panel. Contact Product Support, 800-835-6100 for any other questions regarding this issue.
May 01, 2008 | Office Equipment & Supplies
Xerox Phaser 6300DN Laser Printer Logo
365 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
