Question about GPS
I get message:"Failed to get path to MobileNavigator!"
MY X3-03 GPS WHILE USING THE MAP, FROZE I TRIED TO RESET THE GPS NOW THE SAT. SCREEN COMES UP BUT WILL NOT REBOOT.
Posted on Jul 28, 2009
Exe has performed an illegal operation will shut down. program:mobilenavigator.exe exception 0xc0000005 adress:001394d0 can you help
exe has performed an illegal operation will shut down. program:mobilenavigator.exe exception 0xc0000005 adress:001394d0 can you help
Apr 12, 2010 | JRC GPS
Mobilenavigator.exe exception:0xc0000005 address03fc39ac .?
mobilenavigator.exe exception:0xc0000005
address03fc39ac .?
Dec 26, 2009 | GPS
I get message: "Failed to get path to MobileNavigator!"
your maps are not set up correctly. The unit expects to find thed data in a specific place and that place is empty or does not exist
Jul 27, 2009 | Navigon 2200T GPS Receiver
Message sending failure
Go into:
-meassages/message settings/common settings or anything similar to this that contains the command "reply path"
-activate reply path to yes.
try this,hope this helps
May 01, 2009 | Cell Phones
Nokia 500 gps. Display freezes and has a box in upper right corner. Bluetooth hands free works but navigation does not. Troubleshooting info found on Nokia Wiki says "this means the shell is started...
Try this, I have similar issue with the unit freezes and has a box in upper right corner. Go to the Nokia website, download their software update wizard and follow the instruction. It will flash the unit and fix the issue.
Mar 21, 2009 | Nokia N500 Auto Navigation
Nextar S3 Application error in Navigate
You need the contents of the \ResidentFlash directory. You'll need to rename the MobileNavigator folder and the four gpspara files (0,1,2 and 3) then load the new folder and files from a device that is working. You will then copy your old \ResidentFlash\MobileNavigator\UserData folder from your backup to the new folder to regain any favorites you might have created. You should then be good to go. I use ActiveSync to talk to the S3. I'm not sure how else you might attach to it.
I have the ResidentFlash files but I have no place to post them. The files zip to about 5.3 MB.
Feb 27, 2009 | Nextar S3 Car GPS Receiver
Installing mio pocket on Sanyo 4370
Use SDFree method and assume you have extracted MioPocket on your PC's local drive
  1. Hook up your GPS to a PC via USB cable and note a drive letter
  2. Copy MioAutoRun, SDFree, and Media folders to the root of GPS FlashDrive (drive letter) above
  3. Open MobileNavigtor and rename MobileNavigator.exe to MobileNavigator_orig.exe
  4. Rename all 3 files begin with Miomap in SDFree folder to MobileNavigator (keep the extension intact)
  5. Copy all 3 files and MortScript.exe to MobileNavigator folder
  6. Unplug the GPS and launch MioPocket via the Navigation button. MobileNavigator on top is Sanyo GPS apps.
HTH.
Feb 18, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
Updating an Evesham nav-cam 6400
All you guys, I can help you install IGo8 or other software for your gps with the latest maps and I need the copy of the flash memory for my defective unit.
Normally this unit (at least mine did) look for mobilenavigator.exe on sd card so you can put other software on the card, rename the folder to mobilenavigator and the executable the same mobilenavigator.exe and you have Igo8 for example working on your device.
And for helping me you put instead of mobilenavogator.exe a program called romdump.exe (but ofcourse you have to rename it to mobilenavigator.exe to run). Atfer that this program that I can provide by email will copy the content of the flash memory to SD in a .bin file that I can prelucrate to create the firmware update file and you will be protected in the future if you mess something up.
Waiting for your answer stvaly@yahoo.com
Oct 08, 2008 | GPS
GPS Logo
188 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
