SOURCE: Ice maker stopped working
are the "fingers" of the icemaker pointed toward you and slightly up? if not the icemaker is internally broken . is the red light to the right blinking twice and then a one second pause? if not the emmitter is broken. is the black hose coming from the ceiling blocked with ice ? if so the water vave is broken allowing water to seep in hose and freeze. hope this helps.
SOURCE: maytag ice2o won't make ice
theharrisont, You state that...." ice maker stopped working after it flooded our kitchen floor." The water works because the water fountain dispenser uses a separate part of the Water Valve. The ice maker portion of the water valve is defected and the entire Water Valve Assembly will have to be replaced. Your problem is the dual Water Valve Assembly which is located on the rear bottom area of the refrigerator (follow the water inlet line from the wall to the refrigerator...the water inlet line connects to the Water Valve Assembly). The significant info which you provided was that the ice maker flooded the kitchen which indicates the Water Valve Assembly is defected. Failure to replace the Water Valve Assembly will result in the same problem of flooding at some later date. Replacing the dual Water Valve Assembly is just one step of several steps necessary to correct the problem. You will also have to temporarily remove the ice maker from the freezer (usually a couple of screws hold it to the wall and a quick disconnect electrical plug) and put it in the sink and run warm water over to remove any ice. Before you reinstall the ice maker you must check the Water Fill Tube that dumps the water into the ice maker. Because you said that the ice maker flooded the kitchen, then the Water Fill Tube is probably filled solid with ice which must be removed. A hair dryer is a quick way to achieve this. Blow hot air directly into the end of the Water Fill Tube which dumps the water into the ice maker. Note: Use a long screw driver to insert into the Water Fill Tube to break loose any ice and continue to use the hair dryer to help to remove any ice.
This should correct your problem
If you need further help, I’m available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
SOURCE: Ice Maker not working
Start by cleaning the condenser with a brush and a shop vac. Then get some nickleguard ice machine cleaner and wash the units plate's down going by package directions, then retry before calling a tech. It may start working but if it does not then it may save you some money by having the unit clean before the tech gets there. Ice machines are not a DIY repair. Sowwy
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Ice maker stopped working w/red light blinking
The blinking light is an indication that your built in water filter needs to be replaced, it's in the refer. side, middle top or rear of refer.
SOURCE: ice maker stopped working. In door water
Hi TBurl,
Yeah... classic sign of a failed water valve. You need a new one. The part number is D7742204 (<---plug that into a search engine or call a local appliance parts outfit to get one).
Easy to replace... Just pull the fridge out, UNPLUG IT FROM THE WALL, turn the water valve off at the wall, remove the water line from the fridge valve, then remove the 2 screws mounting the valve bracket to the base of the fridge. All you have to do now is remove the electrical connectors and the tubing from the old valve and place them on the new one (making sure to get the wires right, OK?). Now just mount the new valve, reconnect the water, turn the water on and plug it in!
EASY! All in all about a 20 min. job. There ya go! Your fixed. Don't forget to rate this solution, OK? My self-esteem is depending on you. :P
SG
Before going to buy any parts
directly.
Go through this troubleshooting help links.
This is list of refrigerator problems,
which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
