SOURCE: SAMSUNG PS42D4S PLASMA TV HAS
I had the same problem here but I notice that one of the compoent on the power supply board is melted slightly. Suspect that it might be the cause. the compoent have a symbol of transformer and is grey in color...(look like a cap) ...compoent number is L48
SOURCE: Westinghouse tv ltv46w1hd sound no picture
www.cfusion.com has the spare parts for that tv. it sounds like it is the mainboard. shouldn't be more than 150-200 to replace.
SOURCE: MY toshiba tv MW27F11C only shows a white line when turned on
Hello uuka,
You have vertical collapse. This is most often caused by a defective vertical output integrated circuit, an open dropping resistor which feeds the supply voltage to the I.C., one or more defective electrolytic capacitors in the vertical circuit or something as simple as bad solder connections. The latter will usually manifest itself as an intermittent failure. Less likely, but stilla possibility is a defective yoke, but this a rare.
Unless you are handy with a soldering iron and have some experience this is definitely something I suggest that you refer to a qualified technician. Depending on the actual cure for the problem, this would typically be under $100 in my shop, but we are in a small town and prices are cheap. I would definitely recommend a repair on this since it can not be replaced. They don't make a TV/DVD/VCR combination any longer and the picture quality on these Toshiba/Orion combos has been very good over time.
Hope this helped and don't forget to rate...
Thanks!
The Wing Guy
SOURCE: Palsonic lcd tv will not show any images on screen, hear noise of
means you prolly have something wrong in the tv with the actual board or chip in your tv. im not fimiliar with your model but i have a panasonic viera and it wouldnt tuen on shortly after and they said i had to send it in for repair
SOURCE: TURN ON TV, SHOWS PICTURE FOR A SECOND, THEN THE
there is a bad capacitor in the power board
The Can shaped little device will have a domed or puffed up top on it the value is printed on the side you can , or have someone replace the cap and you should be all set
