Pny Optima Attache Flash Drive suddenly locked
Had used it for several months and then one day it won't let me add any files. Says the drive is write protected. I can get my files off, but nothing goes on or can be deleted.
  • 1 more comment
  • mcdown75 Jul 27, 2009
    Thanks for the suggestion. This is a Pny Optima Attache 2GB. I cannot find any slides on it anywhere. There usually is one, but if it's on here, I don't know where it is. Good suggestion though.
    Thanks for the suggestion. That's the first thing I looked for. I cannot find a slider anywhere on it. Even took it apart and examined the circuit board. Just no luck. Good suggestion though.
    Found it! I have a feeling one of my co-workers (A Linux God who disdains us Windows Gurus) was playing a joke on me. The following came from David Kramer.KA athttp://davidkramer.wordpress.com It fixed it completely. Thank goodness!
    Open the command line editor of windows XP (in my case, and in that case hopefully your, if I am to help you). You find that under ?Start?, the choose ?Run?. There you enter ?regedit?. This starts a little program that allows you to operate within the holiest of sites of windows, the registry. Here all kind of actions and behaviors of the system are set.
    Go to the path:
    HKEY_LOCAL_MACHINE\System\
    CurrentControlSet\Control \StorageDevicePolicies
    This is simply a folder within a folder and so on? The final folder, the one you are looking for is called StorageDevicePolicies, and as the name suggests contains the settings for how the storage devices (USB flash) should behave.
    Here you right click on: ?WriteProtect? and select ?modify?. Here you set the value that appears to ?0″. Press enter and that?s it. (In other words: Default value: DWORD=0)
    Possible values are:
    0 ? Disabled
    1 ? Enabled
    Set the value to 0 and your back in business.
  • 3 Answers
Look for a slider on the flash drive, I had a pny flash drive that had a slider that when enabled would protect the flash drive from accidental erasure or modification of the files.
Posted on Jul 27, 2009
How to remove 'write protected' from PNY Optima Pro Attache 2 GB USB 2.0 Flash. My flash drive named above, always tells me that the drive is write ptotected whenever I want to add or remove a...
If it doesn't have a sliding "write protect" switch on it as shown in step 2, try step 5 or step 6 on this page:
http://www.makeuseof.com/tag/how-to-fix-write-protection-errors-on-a-usb-stick/
Small sd cards have a small slider in the case itself. Flash drives may have partitions on the drive itself. One or two of these small partitions may have write protection on them that cannot be removed. If you have too much trouble, put the flash drive in a usb slot, wait for it to be recognized. Open the control panel and open administrative tools. Click on computer management and then in the left lower pane, click disc management. In the right pane, there will be a window that shows and lists all the drives and partitions. Look for your flash drive and you can delete volumes, partition the drive etc.
remove write protected from PNY Optima Pro Attache 2 GB USB 2 0 Flash...
Mar 05, 2018 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
Last year I copied photos onto my 1GB PNY Attache Flash Drive. I've viewed the photos several times, so I'm sure the photos copied correctly. Now when I put in the flash drive, my computer says 0 files....
Hi
Please follow these steps
1. I think its not a problem with flash drive.
2. There should be virus in your computer.
3. Please install anti virus or if it is already there update it.
4. I think that virus is deleting your files in the flash drive.
Jul 30, 2010 | PNY Attach? 1GB USB 2.0 Flash Drives...
4GB Attache flash drive says it's locked.
Plug in the stick. wait for it to come up on the desktop then click on it once. (do not open it).
From the file menu select "Get Info"
In the panel that opens up you will see a row of coloured squares. Underneath is a checkbox marked "Locked"
Is it empty or ticked?
If it's ticked, untick and see what happens in disk utility. If it's not ticked that then would appear to be a problem with the stick.
For what it's worth, I did a google on this stick and found that there are numerous posts about it becoming read only on Vista, so it may well be a problem with the manufacturer.
Sep 07, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Access issue to my flash drive
The drive is probably password protected by Securlock software.
Hope it helps.
Aug 30, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
My flash drive says I am using data when I am not
i mean when i insert my flash disk in to the computer and then try to open it displays format disk
May 01, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
Write protected and locked files on PNY Optima 2 GB flashdrive
is there a little switch on the side of the usb, if so move it. test with "H2testW"
Jan 25, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
PNY Optima Pro Attache 4 G
Make sure you are using the right port. There are slow and faster ports on a laptop.. So try plugging it into another and see if it helps
Jul 18, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Optima attache
You may need to uninstall your USB port drivers thru the Windows Device Manager and reboot . Windows will see your USB ports when it restarts and reinstall the drivers which will include support for flash drives including Pny flash drives.
Jun 20, 2008 | PNY Technologies GeForce 6200 128MB AGP...
PNY Optima Attache 4g Flash Drive
Change the drive letter of the pny drive to another letter, different than that of your accounting package. Right click "My Computer" click "Manage" select "Disk Managment" right click the drive, select "Change drive letter and Path" and then change the drive letter to something not used on that computer.
Jun 12, 2008 | PNY Technologies GeForce 6200 128MB AGP...
Computers & Internet Logo
285 people viewed this question
David Payne
David Payne
