Stops and seals antifreeze/coolant leaks. Bar's Leaks Radiator Stop Leak Concentrate is specially designed to stop minor to moderate cooling system leaks and ...
Bar's Leaks Radiator Stop Leak Products are designed to Stop Minor to Moderate Cooling System Leaks. Our products are affordable and safe for all vehicles.
Aug. 15, 2019 - Bar's Leaks 1196 Radiator Stop Leak Seal the leaks in your radiator with this concentrated formula. It works to seal small leaks in your radiator or heater core. Bar's Leaks manufactures this product in the United States. One bottle can treat up to 4 gallons.
My mother has one of these units, it was working fine until recently I took it to play with it, and found the same problem you describe. The unit works with the power supply (what some people call the "cord") attached directly to the unit, it works through the connector on the power pack itself, but the LED on the battery is not on as used to. I opened the battery pack and found it has an electronic board close to the power connectors, that board might be defective now, yours might be have the same problem. I'm an electronics tech, but I can't fix that board with surface-mount compontens.
Solution: Contact Haier to see if you can purchase the battery pack. In my case I could replace the internal charging board, if they sell it separate, which I doubt but never hurts try contact the factory.
The yellow is usually the video connector the the other two connectors would be for the right and left channel sound hook-ups.Hope this helps you with you problem.
