Exercise & Fitness Logo
Jelena Letic Posted on Aug 18, 2017
Is any gym good life in aldinga - Exercise & Fitness
Need user manual for Life Fitness G4
Please go to website from Lite-Fitness:
http://www.lifefitness-latinamerica.com/commercial/support.html
in this web page you will download your user manual for free, please give you model, serial, etc, and ready.
sincerely.
E.CUADRA
MANAGUA, NICARAGUA
1helpful
Notify maintenance motor controller comm bad
I own a gym and have 5 9500's...unfortunately it sounds like it the motor controller board which is around $800. National gym supply or sprotsmith has the part.
I just bought a used life fitness 95ti and it seems to be very noisy when it inclines? is this normal and is there a way to call up how much use the machine has had? Thanks
If its growling then the incline motor is on its last leg. All incline motors have some degree of noise my only suggestion is if their is a Gym in area call them and see if they have Life Fitness treadmill don't worry if it is not the same model. The motor have not change much you should be able to gage noise level on a few of the units. They do not have a total mileage or hour usage if this unit came from a gym a loose figure of 20 to 25,000 miles or 3 to 5,000 hours give or take.
5helpful
Our life fitness 9500hr recumbent bike stopped working
If this unit has not been used for that period of time then the 6v batt has died ans needs replacing call National Gym Parts @ 1-800-496-7278 to order part# LC001.5
HERE IS THE PROCEDURE TO REPLACE THE BATT:
Tilt the bike on its side, remove mounting screws securing the battery to the bracket. Remove the battery just enough to access and disconnect the black (neg) wire from the (-) terminal and the red (pos) wire form the (+) terminal. Replace battery and reverse procedure when installing battery
Replacing the drive belt
YOU CAN PURCHASE AN MANUAL FOR ABOUT $20.00 TO $25.00 PLUS S/H FROM THESE PEOPLE : NATIONAL GYM SUPPLY 1-800-496-7278 THEY WILL NEED M# AND SERIAL#
My Life Fitness 5500R (like 9500R ) Recumbent's display works but when I press the program button it doesn't cycle through to Hills, etc.! Suggestions?
sounds like the keypad is not functioning since this is one of their older model I recommend call Life fitness and see if parts are available their # is 1-800-351-3737 they will probably will ask for a s#
4helpful
Multi gym
I have the multi gym at home all set up.. can send pics of it..
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
