SOURCE: Hello! My GE Dishwasher (Model
I need to know is the water not going in the machine at all in other words when you switch on the machine with the tap open can you hear the water flowing,if you can here the water flowing check the hight of you drain hose if it is too low down you will find that you end up with a syphoning effect as the water goes in the machine it gravity feeds out the drain pipe if the drain pipe is low lift it up (about half way of the machine is a general indicater) if you cannot here water flow and the tap is open and machine on it could be your inlet solonoid,it may also be your pressure switch if the machine was tlted it may get water in the pressure tube in wich case you will need to locate the pressure tube and blow it clear if there is water in the pressure tube the pressure switch will think the machine is full,worst case is the (timer or pc board) wich ever your machine has is fualty but this is seldom the case
SOURCE: seeburg jukebox sx 100 scans twice and returns
THIS JUKEBOX IS 40 YEARS OLD. LUBRICATION MAY BE THE PROBLEM. HERE IS HOW TO FORCE THE SEEBURG JUKEBOX TO PICK UP A RECORD AND PLAY A SONG.
LOOK AT THE ARM THAT HOLDS UP THE NEEDLE AND CARTAGE. NEAR THE MIDDLE OF THE RED ARM, ONE INCH TOWARD THE MOTOR, THERE IS A HORIZONTAL LEAVER LIFT IT UP A RECORD WILL GO INTO THE HEAD, THAT RECORD SHOULD PLAY THE SONG, IF THE LUBRICATION IS OK.
IF THE RECORD GOES INTO THE HEAD, AND THEN PUTS THE RECORD BACK IN THE RACK. YOU HAVE A LUBRICATION PROBLEM.
THAT IS A TOUGHT MACHINE TO FIX IOF YOU ARE NOT FAMILIAR WITH IT.
DOCTOR FIX IT.
SOURCE: Our Company purchased 3 Motorola AXU4100 4 watt 10
There should be a an Authorized Motorola Dealer in your area. Check your yellow pages under radio communications. It would be a question to whether the local dealer would repair this model.
If you cannot find a local dealer who repairs the AXU4100 style radio, use a search engine to look up Motorola CP125 radio repair. (This is the equivalent radio in the business division.) Flat rate repair for this style radio is approx. $69 ea.
Best regards.
SOURCE: my seeburg disc jukebox skips a lot
try going into service mode to find the problem could be different things also you could try cleaning the laser this is one of the easy options
