SOURCE: I order two DIGILAND TABLETS AND I NEED TO KNOW
go into setting look for wifi and turn it on !
SOURCE: My digiland tablet will not charge or turn on
Check the charger with another device or try a known good charger.
SOURCE: Battery will charge to 100% only 50%
Its probably because of your tablets power source. If you have used your tablet very often then it will begin to cause the battery to drain more quickly and it will also not fully charge. It could also be a problem with your charger. There could be a short in it or something else that would cause it to stop charging the device at a certain point. The tablet isn't powered by a removable battery so don't try to open up the back and tear out any circuit that you think is the battery as this may cause even more damage to your tablet. If you have a warranty on the device then try taking it to the store you bought it from and see if they can help, but if you don't then be prepared to spend some cash. You could also take it to a tech store (if you know of one) and maybe they could run a diagnostic on the tablet to see what's wrong. If you're trying to charge your tablet while its turned on it could also be the amount of apps that you have installed on your device. Apps can actually cause put a strain on the battery and cause it to preform poorly. Try to avoid large apps (apps that take up a lot of space) because they can actually cause the device to run slower and it will also force more power to be drained from the battery which in turn will keep the battery from charging fully while its on. Try either one to see which one works for your device.
SOURCE: My digiland tablet will not turn on or charge
check with the battery.eirher it has loose connection or has expired
SOURCE: I forgot my password to my Digiland tablet 10.1 anyone with answer, please reply. thank you!
Factory reset! Turn off, press power and volume+ together until reset screen, select factory reset!
