10 blinks can be a host of problems with the television. Something has failed and tripped the SOS detect circuit (causing the 10 blinks).
You would have to take this thing apart and trace down voltages from the P, A, D, SC, SS boards to determine what could cause it. Hell, even the memory card reader on the front can cause a 10 blink error.
You will want to see a professional.
SOURCE: panasonic viera wont come on
The problem is not the power supply, is with the tunner board voltage. change the P.A board fix the problem.
SOURCE: panasonic model #TH-50PX75U wont turn on, it
Usually seven blinks indicates a Y sustain problem. Its either the Y sustain pcb and/or the buffer boards. I would highly recommend calling an authorized service center for this if you don't know what you are doing.
SOURCE: The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
SOURCE: Panasonic TH-42PX60U plasma TV: red blinking light
are you using a PC to feed a signal or maybe a cable with an adapter?
I had the same issue when I used one of the rear HDMI ports to show a PC display. Apparently there is a software difference between the rear and side/front ports. Inputting the PC through the side HDMI port has solved the problem for me (so far!)
