Question about Whirlpool Duet GHW9150P Front Load Washer
I have no power to my controls. I have power at the outlet, but the washer will not turn on.
  • 29 Answers
Test on button for resistance w/ a multimeter
with button held down it should read 0 you'll need to disconnect wires to the button first and touch one lead to on side of button and the other lead to the other side of the button. If it doesn't read 0 replace on button.
Posted on Jul 28, 2009
Gwl10u2 fisher paykel washer iwl15 can't get it to turn on? Checked the outlet,it's ok. Tried another outlet, still nothing! Help!!!
the fuse on the motor controller has blown. you can replace this fuse, but you will most likely have a short circuit / fault in the pump or motor. check for signs of wear on these, and check for earth faults before re powering machine with new fuse / motor controller.
Sep 17, 2013 | Fisher and Paykel GWL11 Top Load Washer
My washer want start
see this steps and fix it. God bless you
Check Power
Check the outlet by plugging an appliance into the same outlet the washer was plugged into an running the appliance a hair dryer works good for this it will draw some amperage. If it works fine move on.
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control
Jul 09, 2013 | Frigidaire GLTF2940ES Front Load Washer
Why is my washer not starting
Check Power
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control board
Washer will not turn on,power works to the electric outlet.
If you have no display and you have power to the machine, then you will need to replace the "control board". Here is the part you need.
Oct 31, 2012 | Frigidaire Affinity ATF8000FE
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
I HAVE POWER BUT THE CONTROL PANEL HAS NO POWER
Check Power
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control.
Oct 02, 2012 | Maytag Neptune MAH6500A Front Load Washer
DE PUSH POWER BUTTON POWER COMES ON GOES RIGHT BACK OFF, IF YOU HOLD POWER BOTTON IN AND TURN KNOB TO A CYCLE THEN PUSH START BOTTON ERROR dE COMES UP
Check the outlet first. If the outlet is ok, then you have a control board issue. Replace the control board. Good luck.
Jun 19, 2011 | LG WM2487H Front Load Washer
LG Tromm washer powers on but turns off a second or two later. I don't see any error code since it turns off right awat. What can be the problem?
Try using another outlet. Connect an extension cord to another outlet away from the room you are in and see if that will resolve the issue. If it does, you will need to call an electrician to resolve the electrical outlet problem. If the machine continues to shut off, you will need to have the control board on the washer replaced.
Good luck
Jun 16, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing machine will not turn on. yes i checked the outlet
Make sure that the outlet is working even though the breaker is okay. Plug a small lamp or appliance into the washer outlet to verify that it is working.
If the outlet apparently has power the plug the washer back in and listen carefully for a click from the CCU (Central Control Unit or main control board shown in the first image below). If you do not hear a click then I recommend that you unplug the washer and remove the top panel (shown in the first image below). Check the wiring harness connections on the control board. I provided a wiring diagram in the second image that shows the path of power to the CCU. If you have a volt/ohm meter and the technical expertise, you can check the continuity of the power supply to the control board (wires traced in red and green on wiring diagram below). If the CCU is apparently getting power but does not click shortly after it is plugged in then it will need to be replaced.
You could also have a failed user interface touchpad assembly that would prevent the washer from powering up.
These tips may help you determine the cause of this washer failure.
Jan 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Got a hoover washer /dryer wdm 1300 , it wouldnt empty properly, watched the impellor on the pump and some times it would run and then stop , a quick flick with a screw driver and away it went again ,also...
HI CHECK THESE....
Step 1: Make sure the washer is receiving power. Check the cord, the plug, and the outlet. If a wall switch controls the outlet, make sure the switch is working. Look for blown fuses or tripped circuit breakers at the main entrance panel. If the unit is receiving power and still won't run, press the reset button on the control panel (if the washer has one).
Step 3: Make sure that both water faucets are turned on and that the drain and soap-saver return hoses are properly extended, without kinks. If the washer has a water-saver button, make sure the button is depressed; water may not circulate through the filter nozzle if the basket is not full and the button is not depressed.
Step 4: To make sure the water is the proper temperature, check the temperature selector switches on the control panel to make sure they're properly set. Also check the water heater temperature control. It should be set no lower than 120 degrees F.
THANKS
Sep 12, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
80 people viewed this question
Dan Webster
Dan Webster
Sal De
