Question about Tomtom One XL GPS Receiver
Freezes up after being powered on - Tomtom One XL GPS Receiver
  • 25 Answers
Make sure you are getting a good satellite signal. If you are not in a building it should start working after a few minutes. Does it say "gps signal lost ___minutes ago" in the bottom left hand corner?
Posted on Jul 28, 2009
Hp procurve 2510g-48 switch keeps freezing up after power outage
Sounds like the power outage was caused by a power surge. That could have damaged the switch, hence the reason for the freezing. I would look to getting it replaced.
Apr 30, 2014 | HP Computers & Internet
Samsung refridgerator regularly beeps with power freeze switching on and off
Sounds like a faulty temperature sensor calling and not calling for the power freeze to come on. Change the sensor!
Jan 01, 2013 | Samsung Refrigerators
I am not sure on how to wire the freeze protection wires to the time clock. i know they must go to the load side of the clock for the main pump but will this reverse the power back into controls and short...
Here's a 240V diagram with clock timer and freeze control:
Add a comment if explanation does not fit your exact timer:
See image full size:
http://waterheatertimer.org/images/Freeze-protection-500.jpg
Here's how freeze control works:
Freeze control is like regular timer, except it turns ON by thermostat instead of time-clock
Freeze control turns ON pump whenever thermostat kicks on.
Both clock-timer and freeze-control are wired to pump in 'parallel' so to speak.
Think of it as having two controls wired to same pump...
Both controls can turn pump ON-OFF.
If one turns ON, and other is OFF ... then pump is ON.
If both are ON, then pump is ON ... and electricity just flows around on extra wires.
If both are OFF, then pump is OFF.
Say it's below freezing all day.
Freeze control circuit is ON all day ... pump is ON all day
Clock timer turns ON > but circuit is already ON, so timer just opens more wires for electricity to flow around on.
When clock timer turns OFF > freeze circuit is still ON because it's below freezing ... pump is still ON.
240V wiring:
Power leads coming from circuit breaker go to terminals 1&3 on clock-timer
Same power leads connect to freeze-control-black and freeze-control-red.
Or connect freeze-control-black and freeze-control-red to terminals 1&3
This action puts power to clock and power to thermostat
Pump wires connect to terminals 2&4
Same pump wires also connect to freeze-control-blue and freeze-control-yellow.
Or connect freeze-control-blue and freeze-control-yellow to terminals 2&4
This action connects pump to both freeze-control and timer.
When either clock-timer or freeze-control turn ON, then pump turns ON.
Nov 15, 2010 | Intermatic Timer PF1222TB Multi Circuit...
POWERS UP BUT THEN FREEZES AFTER ABOUT 4 MINUTES
Need to test and isolate where it exactly freezes? After dell logo, after windows logo or while inside windows? Now, if it only freezes inside windows try to turn off your windows updates and antivirus first and check if still freezes, if yes then try booting in safe mode, reboot system then keep tapping on f8 once dell logo appears. Check if laptop keeps freezing in safe mode. Please let me know.
Oct 01, 2009 | Dell LATITUDE C600 PIII 750MHZ 128MB 15GB...
Frigidaire side by side - fridge side temp too low
It sounds as though your thermostat is not cycling your compressor off causing it to run until the point of freezing. If you sit and listen, you will hear it hum. If it never stops humming, 9 times out of 10, the power outage shorted your thermostat.
Jan 30, 2009 | Frigidaire FRS26R4A Side by Side...
Computer freezes on start-up
whenever your doing a cd recovery you need to remove the battery
use ac power
if its still freezing up you'll have to run windows again
Windows uses a lot of power to install
Jan 09, 2009 | Acer Aspire 3000 Notebook
Power Supply Keeps Tripping Fuse
Freeze the capacitors is a trick worth trying. These usually are the problem
the way you run this is too use freeze spray to freeze each capacitor one at a time . Turn the TV on and if it doesn't trip for a few second longer you know that is the capacitor to change. Freezing capacitors only helps identify the fault if it is a capacitor issue (usually is with power on TV's)
Dec 24, 2008 | Philips 32MF231D Television
Tomtom One XL GPS Receiver Logo
186 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
