Question about Refrigerators
Samsung RB215 -How do you remove the bracket that holds the door
Samsung RB215 - How do you remove the bracket that holds the top door? It is a triangle piece of plastic. I need to remove this part to be able to adjust the door. An exploded diagram would be good - I have removed one screw - which was holding - It should just snap off - but I don't want to force it.
  • Anonymous Mar 26, 2014
    holding water in bottom of fridge
  • 82 Answers
The Cover hinge is misaligned, causing a no cool situation, the door switch and magnet are out of alignment, the door alarm is also on
The Blue arrow shows the hinge improperly aligned, the Yellow arrow shows the correct position of the hinge
f8ccb64.jpg Solution: Using pliers adjust the height of the hinge by pushing it down, the cover hinge will align properly as well as the door switch and the magnet, energizing cooling fan and
having refrigerator cooling properly.
Posted on Jul 27, 2009
    Novelist:
  • 108 Answers
I'm not completely sure about the Samsung, but usually there is a plastic cover that is held on with a single 1/4 hex screw, after that it just snaps off.
How to remove freezer door with water/ice dispenser on GE profile TFH22PRSM
TAKE OFF KICKPLATE ON BOTTOM OF UNIT. UNHOOK WATER LINE FROM QUICK CONNECT UNDERNEATH. ON TOP OF FRIDGE THERE IS A COVER OVER THE DOOR BRACKET. REMOVE THAT COVER. THEN REMOVE THE 2 OR 3 SCREWS HOLDING BRACKET TO TOP OF FRIDGE. THEY USUALLY ARE 5/16TH SCREWS.MAKE SURE THE HAVE DOOR SHUT OR SOMEONE HOLDING THE DOOR WHEN DOING THIS. AFTER REVING SCREWS AND BRACKET LIFT DOOR UP OFF BOTTOM HINGE AND WATER LINE FROM DOOR WILL COME OUT WITH IT.
Jan 17, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
NEED TO REMOVE BOTH DOORS TO GET REF IN HOUSE.
This should be a very simple thing to do. At the top of your refrigerator you have a bracket with two or three bolts holding bracket to the refrigerator,the bracket has a pin at the end that goes into the door. Unbolt the bracket at the top ( HOLD OR HAVE SOMEONE HOLD ) the door so it does't fall to the ground. Remove door ,put to the side for now. Also remove the bracket at the bottom of the refrigerator that the door was sitting on. Do the same thing for the other door and to give you even more clearance remove the bottom breather cover by just pulling it off. You should have more then enough room to get your refrigerator to where your going .Reverse all steps to install doors. If you need any additional help I would be more than happy to assist. GOOD LUCK.
Sep 08, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do I get the top off
The front panel needs to be removed first before the top panel can be lifted. This is due to the top panel hold down brackets hidden behind the front panel posts. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly. Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip.
Open the door then lift the front of the top cover and tilt it toward the rear of the dryer. Reinstall the top cover and the front panel by following the removal steps in reverse order. Click on the link below for more detailed disassembly procedure.
Removing the Front and Top Panels of Maytag Sloped-Front Dryers
Mar 03, 2011 | Maytag Neptune MDG5500AW Gas Dryer
How to open the top of a Maytag MDE9206 dryer? Makes loud noises want to investigate
The top cover is attached to two hold down brackets, one on each side, and it can only released once the front panel is removed. Disconnect power then open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket.
Swing the bracket to the outside and unhook it from the slot in the top cover lip.
Feb 10, 2011 | Dryers
HOW DO YOU REPLACE THE DOOR LOCK I NEED TO KNOW HOW TO GET AT THE LOCK THE WASHER ONLY LOCKS IF YOU HOLD IN ON THE TOP OF THE DOOR
Disconnect power then open the dispenser cover and remove the four screws securing the dispenser bezel to the top cover then lift the bezel off. The top cover with the dispenser bezel off can be lifted to the rear of the machine to access the door locking mechanism, but you have to remove the front panel first.
Open the machine door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel then move it away and set it aside.
Open the door then lift the front of the top cover and tilt it toward the rear of the machine. The door locking mechanism can now be removed and replaced.. Reinstall the top cover and the front panel by following the removal steps in reverse order.
Jan 19, 2011 | Maytag Neptune MAH5500B Front Load Washer
How do you remove the top of the dryer to access the tube
Open the door then lift the front of the top cover and tilt it toward the rear of the dryer. Reinstall the top cover and the front panel by following the removal steps in reverse order. Please leave a message if you find this post helpful.
Oct 24, 2010 | Maytag MDE6657BY Electric Dryer
Remove top to get at drum
The front panel must be removed first. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Oct 23, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How do I remove the top and front panels of my Maytag MDG7600AWW dryer?
Open the door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
The top panel is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top panel lip.
Open the door then lift the front of the top panel and tilt it toward the rear of the dryer.
Reinstall the top panel and the front panel by following the removal steps in reverse order.
May 06, 2010 | Maytag MDG7600AW Gas Dryer
How to remove top of Maytag dryer
The top panel can be lifted only after the front panel is removed. Open the door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Apr 28, 2010 | Maytag Neptune MDE4000 Electric Dryer
My neptune dryer has an interior 'fin' that is loose (mde5500ayw)
There are screws holding the fins on the outside of the drum. To get to them:
  • remove door
  • remove screws on the opposite side of the door screws (which would hold the door if it would open to the opposite side)
  • pull the top of the front panel, which was held by those screws outwards
  • remove the front panel. You'll see brackets holding the top of the dryer in place. Remove screws holding those brackets.
  • lift the top.
Good luck
Oct 20, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Refrigerators Logo
182 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
