Question about Garden
I have a Scotts Turf Vac3 self propelled mower. Dog got ahold of the cable and now the ''self propelled'' feature dont work. SUPER hard to push since the drive wheels wont go, how do I fix it?
  • lnmwrguy May 11, 2010
    NEED MODEL NUMBER
  • meefong
    meefong Jun 21, 2014
    229963X8A
My pulling string has broke and i am trying to replace HELP! have taken apart
Posted on Aug 14, 2009
  • 80 Answers
If it is a briggs and stratton there is a preloaded assy available
Posted on Aug 30, 2012
Scotts turf vac3 6 5hp
ck. and make sure fuel cap is venting properly.
Jun 14, 2013 | Garden
6.5hp i/c intek edge starts with prime runs a few secs and dies ??? I just bought this mower used. no info on history. ran fine for first two uses. the motor is on a scotts walk behind mower turf vac3 ?...
Check the brass bolt that holds the carb bowl on. Remove it and clean the tiny holes on the smooth part above the threads. Carb and Choke cleaner should do this. This is actually the main jet for the carburetor and when partially clogged causes exactly the problem you are having. Clean the bowl too while you have it off.
Jun 02, 2010 | Garden
My toro self propelled lawn mower won't roll backwards... the wheels are locked up
My Toro Pace Master self propelled 22" 6.75 mower will not move by itself. I can push the mower and cut. It does start with no problem. I have a cable on left side of the mower that extends to the top of the handle broken off at the top of the mower and is loose. Is there a way to check to see if this is why it will not self propel. It attaches to the push handle that does I push down to propel the mower. Any suggestions?
May 07, 2010 | Toro Lawn Mower With Toro Power Tools
Self propelled mower no longer propells
SOUND LIKE THE TRANS IS WORE OUT
Oct 01, 2009 | Garden
Self-propelled feature does not work at all! Any suggestions?
You might have a broken belt to the self propelled or a broken spring or whatever engages the self propel. Take off the cover and see if anything is broken or missing. Have someone engage the self propel while you are watching and see what is going on.
roundo4
Aug 12, 2009 | Toro Lawn Mower With Toro Power Tools
My toro self propelled isn't self propelling
It may just be a matter of adjusting the cable. Sometimes they dont get them adjusted just right from the factory,heres what you do. Locate the plastic shroud in front of the push mower that covers the drive unit.Determine which screwdriver or torx bit is needed to remove shroud and remove it. After removal you will see a pulley with belt around it, as you pull the handle back to engage self propel you should see the pulley move into the belt to put tension on the belt. You can do this with it running to see if enough tension is being put on the belt,if not, locate the cable end where the small bracket holds the cable in place. Loosen the cable bracket and move cable until you have correct tension again,hope this helps.
Aug 08, 2009 | Garden
Self propel always engaged
you may have lost the spring that pulls the transmission drive belt down or have the cable adjuster too tight.word of caution here, the cable goes thru the engagement lever and if you overtighten it the lever will crack or break. if it does the complete transmission will have to be replaced.seems they dont make the lever avalible seperate.
Jul 09, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
1,202 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
