There is a sound coming from the back but is this just the compresser for the freezer
Usually there is only one compressor. Cold air is allowed into the refrigerator with either a vent door (damper) which is mechanically controlled by a numbered dial, or in fancier models, an electronic damper which opens and closes to regulate the temperature in the fridge.
The problem could be that the damper isn't working properly (usually the case, but not always) or that the thermostat or control board is not sending power to the damper motor.
SOURCE: JENN-AIR REFRIDGERATOR JSD2789AES
HI thanks for your question. remove cover to the compressor relay, check for burnt wires. clean all coils. replace the relay. thanks
SOURCE: fridge & freezer warm clicking noise is coming from compresser
It sounds very much like your defrost timer is gone. Pull the botom panel of the fridge off and you should see a circular unit with a screwdriver slot in it. Turn the slot CLOCKWISE only until you hear the fridge start up. If it does than you've gotten off cheaply. These defrost timers are inexpensive and, after unplugging the fridge, you can change it your self. It's as simple as changing a tire.With less bullwork of course.
SOURCE: Smeg CR330SE fridge/freezer hi there fridge
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
