Question about NetGear Computers & Internet
I have connected the netgear GSM 7324 switch to my PC. how can i check the communication between the console port and my PC
  • 1,272 Answers
Hi, The best support you will get for this product is by logging to NETGEAR support site my.netgear.com
Posted on Jul 28, 2009
I have forgotten my netgear switch fsm726 v2 username & password
Your username is almost assuredly administrator. You may have to do a reset to get the password.
Mar 25, 2013 | NetGear FS108 Networking Switch
NetGear FSM7326P reset to factory default
Netgear FSM (and GSM) switches have an RS232 serial console port. Connect to that using Hyperterm, PuTTY, Xterm etc. at 9600-8-N-1, and power up the switch. Early in the boot process, it will give you a choice of normal operation, or the boot menu. Select the boot menu before the time runs out (usually a couple seconds), and one of the options will be to reset the switch configuration, including the password.
As far as I know, there is no way to recover the password and leave the configuration intact.
Mar 01, 2012 | NetGear FSM7326P Networking Switch
Have secondhand gsm7312 and don't know username or password. How can I factory reset this unit? There is no reset button and I can't enter menus via console cable as it asks for username (not the...
Jul 26, 2011 | NetGear ProSafe GSM7312 Ethernet Switch...
Not connect from console port
Verify that the correct settings and cable/connectors (rollover cable, correct COM port specified) are being used when establishing the console connection.
From the manual-
3.9.2 Connecting to an IBM or Compatible Device
To connect an IBM PC or compatible device, running the VT terminal emulation, to an
Enterasys Networks module Console port (Figure 3-20), proceed as follows:
1. Connect the RJ45 connector at one end of the cable (not supplied) to the Console port on the
Enterasys Networks module.
Connecting to Console Port for Local Management
Hardware Installation 3-31
2. Plug the RJ45 connector at the other end of the cable into the RJ45-to-DB9 adapter (supplied
with the device).
3. Connect the RJ45-to-DB9 adapter to the communications port on the PC.
4. Turn on the PC and configure your VT emulation package with the following parameters:
Parameter Setting
Mode: 7 Bit Control
Transmit: Transmit=9600
Bits Parity: 8 Bits, No Parity
Stop Bit: 1 Stop Bit
source: Install Guide for Enterasys 1H582-25 / 1H582-51 (http://www.retrevo.com/support/Enterasys-1H582-51-Switches-manual/id/2785dj098/t/2/)
Jun 22, 2011 | Enterasys MATRIX E1 (1h582-51-g)...
Cannot restore to factory default Netgear gsm7212
Netgear GSM switches have an RS232 serial console port. Connect to that using Hyperterm, PuTTY, Xterm etc. at 9600-8-N-1, and power up the switch. Early in the boot process, it will give you a choice of normal operation, or the boot menu. Select the boot menu before the time runs out (usually a couple seconds), and one of the options will be to reset the switch configuration, including the password.
Dec 16, 2010 | NetGear ProSafe GSM7212 (GSM7212NABND)...
How to connect netgear fs108 to cable modem
leeb..... switches cannot be connected to the Cable modem.... because NAT will not be enabled in cable modem....so there wont be any DHCP server present in the cable modem....
Nat will be enabled only in DSL modem like AT&T verizon etc....So DHCP server will be present inside DSL modem...that is the reason why switches can be connected only to the DSL modem....
With NAT enabled modem, switch will work as a switch.... With NAT disabled modem, switch will work as a hub.... This is the difference....
Any doubts further ? please clarify with me.... I am ready to help you....
May 09, 2010 | NetGear FS108 8-Port Ethernet Switch
GSM712 Netgear Switch password reset or recovery
As far as I know, you'll need Netgear's help to recover the passwords and they'll only help if you have a Premium support contract.
Try "1234" as this is the default if password protection is enabled.
Oct 03, 2009 | NetGear GSM712 Managed Gigabit Ethernet...
Ps3 internet connection
here is the code to enter at DNS 4.2.2.2 and 4.2.2.1
Jan 02, 2009 | Sony Playstation 3 (PS3) Console
Open Port 81 on Netgear Switch
Actually you need to open the port on the cable modem / router. Switches just pass the packets along.
May 20, 2008 | Computers & Internet
Computers & Internet Logo
242 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
