1 answer · Top answer: Good afternoon. My name is ***** ***** I'll be assisting you with your appliance today. Please ...
Missing: 110.77741600 ‎' Show results with: 110.77741600
If you tip the washer up against the wall at about a 45 degree angle, you can look under it. The coupler is in between the motor and the gearcase.It's about the size of a yo yo.It has three pieces to it, two white and one black.They are connected buy three fingers on both white pieces.Please be careful while you are looking be sure to have someone helping.
The model number on Kenmore top loaders is usually printed on a nameplate along the wash tub rim opening under the washer lid. The model number has 8 digits with a prefix of "110". If you cannot locate it, please let me know. I hope this helps you.
If you are looking for an Owner's Manual, go to managemyhome.com and type in your model number in the following format: "110.28032700" under the "Manuals" link. Your owner's manual is available in a .pdf (adobe) format that you can download or print for FREE.
If you need technical data sheet to troubleshoot a problem, the washer comes with a tech sheet inside the cabinet. It is located between the wash tub and cabinet in the front of the washer. The tech sheet includes all diagnostics procedures, fault codes and technical data to troubleshoot any problems you may encounter.
You can access it by lifting the washer top, or by reaching up from the bottom of the washer. If you choose to open the washer top, you need to locate the two retaining clips along the front of the washer in the seam where the top panel meets the front of the washer. Push in on the retaining clips and the top panel will pop free and can be lifted up. Make sure you hold the lid closed while lifting, so that it does not fly open when lifting the top. I recommend taping it closed.
If the tech sheet is missing, you can order a new one. The part number is W10026628.
If you have questions, please let me know. I hope this helps you.
If you are looking for an owner's manual for your washer, go to managemyhome.com and register. This is a FREE service. Once registered, log in and locate the "Products and manuals" link under the "Home" drop down menu. There are two manuals listed for your washer in down loadable .pdf format. I hope this helps you.
i have the agitator dogs, but my agitator is not turning. Can you help me in getting it off. kenmore model 11022954100. please help !!!!!! wife is tearing me up!
