Question about Sony Playstation 3 (PS3) Console
At home we use HDMI cable for video out, we are on vacation & have the unit plugged into a tv using the red,white,yellow cable. Is there any way to get the unit to work?
Sure !! you should simply turn the ps3 system on by HOLDING the on;off button. it will restore you settings to AV cable unit =]
Posted on Jul 27, 2009
Connecting DVD player to spectre ledTV
It should be hooked up just like any other tv would be. The output of the DVD should match the input you're going to use on the tv. If you're going to use an HDMI connection then both units have to have HDMI connections. If not HDMI, then either composite connections (RCA plugs that are colored red, white and yellow). Each color go from and to the same color on each unit. You may also have an 'S' video (usually yellow colored). If you use this connection then don't use the RCA yellow connection. The S video connection has a better picture than the RCA connection. Either way, you still have to use the red & white (or black) RCA connections for the left & right audio. However, if you use the HDMI connector then you don't need the red & white audio connections because audio is already in the HDMI connection.
Aug 18, 2017 | Televison & Video
Please tell me how to hook up my Wii and my cd player and my dvd player to Pioneer VSX-D309 receiver
Greetings and good health to you.
Ok, so on the back of the unit there should be labeled connections, AUX, DVD, etc. These will be your inputs.
If your Wii has RCA connectors (the plug like ends that are usually Red, White & Yellow) then you would connect the Red plug to the AUX right speaker input. The White plug to the AUX left speaker input. If you want to run the video through the unit to the TV, then you would plug the Yellow plug to the AUX video input. If not, the yellow plug with go straight to the TV. If you are using HDMI from you Wii, then you would plug that into one of your HDMI inputs.
You will do the same for CD player but using the inputs labeled CD or whatever you have available. You can use any of these inputs for any of your devices it just helps to know what is connected where.
The DVD player may be a different story. Depending on what type of connection you are using from the DVD player will depend on where you plug it in. If they are red, white and yellow...then follow as above. If they are red & white on half the cable and blue, green and red on the other, you will plug the red & white ones that are close together into the red and white audio inputs under the DVD labeled connections. Then the other 3 will go into their matching colored inputs. If the connection from the DVD player is HDMI, that will go into a HDMI slot.
Finally, connect the unit to the TV. Keep in mind that if you are using any HDMI inputs, you will need to connect the unit to the TV via a HDMI cable.
Hope that helps.
Nov 05, 2015 | Pioneer VSX-D307 Receiver
Connecting my new samsung blu-ray player (bd-fm57c) to my toshiba theaterview tv.
I don't think that cord will work. HDMI carries video and audio signals, you might get video but probably no sound. You might as well try anyway though so here goes... The red green and blue plugs are your video and the other red plug and the white plug is for stereo sound. The yellow plug is just a lower quality video plug. So plug in the red blue and green plugs into the component video inputs on the TV then the red and white plugs into the audio inputs. DON'T plug in the yellow plug. If this doesn't work go to your local home theater store and ask for a receiver or switcher that will downscale high def HDMI to component video and stereo audio. You can probably pick up a cheap one for around $100. Good luck!
Mar 29, 2014 | Toshiba 50 Inch Big Screen Flat Tv Theater...
Trying to hook up my wii but have sound and no picture I have HDMI cable from tv to yamaha v373 amp and trying to connect the red white and yellow cables to back of amp
Need to put yellow cable into monitor in and choose a input with video vcr, tv, or dvd. still no luck then yellow directly to tv.
Dec 08, 2012 | Yamaha RX-V373 5.1 AV Home Theater...
How do I hook up my maxent tv to cable
use 1 of these 4 options
On the back of the cable box there should be outputs
Coaxial ( regular cable wire that screws on)
RCA plugs (yellow red & white )
Component plugs ( green, red, blue for video) (red, white for audio)
HDMI ( on HD cable box only)
After connecting make sure your tv is on the input you connected on the back of the TV
Dec 04, 2010 | Maxent Televison & Video
No colour
Hi, Definitely a TV issue for me. Changed Wii to another input on TV and resolved situation. Need now to check how to get my TV to recognize colour on AV2 & 3 because I prefer to keep DVD input as AV1!
I had to use the (RCA) video inputs and not the component inputs. These are the ones made for video games. If you want to use the component input (Component cables are Red,White Red, Green, Blue). If you don't have any, you should be able to purchase them at your local electronics store like Radio Shack or Best Buy. Hope this helps, read below:
TV (This is your cable connection or TV; coax)
Component 1 (Must use component cables for this input/output; Red and White for audio, Red, Blue, Green for Video)
Component 2 (Must use component cables for this input/output; Red and White for audio, Red, Blue, Green for Video)
HDMI 1 (HDMI Cable)
HDMI 2 (HDMI Cable)
Video 1 (Must Use RCA cables, or RCA jacks; Red and White for Audio, Yellow for Video)
Video 2 (Must Use RCA cables, or RCA jacks; Red and White for Audio, Yellow for Video)
Sample of Component Cables:
http://www.tigerdirect.com/include/AddCartfromGallery.asp?EdpNo=245214&csid=ITD&Sku=C184-27083&imgcart=1
Oct 07, 2010 | Nintendo Wii Console
How to connect nintedo to plasma tv
Hi,things you will need,
  • Video game console
  • HDMI cable
  • Audio/visual cable.
  1. Plug in your video game console's power source.
  2. Connect one end of the game console's audio/visual cable into the corresponding slot on the console if you have an older game console. If you have a newer console, insert one end of an HDMI cable into your console's "HDMI OUT" port.
  3. Plug the red and white ends of the audio/visual cable into the corresponding red and white audio inputs located on the back of your Vizio plasma TV if you have an older game console. Plug the yellow cable into the yellow "Video In" input. Depending on which model of Vizio TV you have, the yellow input may be located either right next to the audio inputs or it could be located a few ports away.
  4. Plug an HDMI cable into one of your TV's "HDMI IN" ports, if you have a newer console.
  5. Turn on your video game console and your Vizio plasma TV. Press the "TV/VIDEO" button on your remote to cycle through the various inputs. You should eventually get to an input that's displaying your video game console's home screen.
I think that will do.
Have nice day.
Sep 25, 2010 | Nintendo Video Game Consoles & Games
I have a blu-ray disc player. Model Bd-C5500. It seems to be telling me I am not connected to HDMI cable. I have connected the cable to the HDMI out terminal on the rear of the player to the HDMI in on the...
HDMI and the red, white, & yellow cables are two different sources. Try using the remote to switch playback source from HDMI to the other choice not sure what Samsung calls the red, white and yellow connectors. I can tell you that the red cable is audio right, the white cable audio left and the yellow is the video.
Jun 28, 2017 | Sony HESV1000 200 Disc Blue-Ray Server
I need a diagram on how to hook up my vizio tv to a tuner, direct tv and a dvd/vcr
At the rear or side of the PC there should be either or both of a 15 Pin DIN Plug, HDMI socket. or a Yellow RCA or 4 -7 pin DIN. Now IF these are present then YES you can connect to a TV. Now some TV's have a connector a DB15 MALE, so that the cable from the PC to the TV, is DB15. this plugs in directly, with appropriate DB15 cable. This, however, will ONLY take the VIDEO to the TV, Audio is delivered via the "Audio Out" Jack on PC, and Plugged into the AV Sockets on the TV, with a dual cored coaxial cable, they are Red & White. Some PC's also have a Yellow RCA Connector, OR a 4 -7 Pin DIN Socket, that requires a Special Adapter Cable (That generally came with the unit, and are colored and marked as to output) to use, for Video/Audio Out to TV. This signal is Composite or SVHS Video & Stereo Out. This connects up TO the TV's Composite/SVHS input Jacks and the Red & White Audio IN, RCA Jacks, &/or DIN SVHS socket. Also we have "Component Video" marked "Y" "Pb" & "Pr" these simply go color to color at BOTH ends, this is where the Red, Green, & Blues, colored Ends, of the Wires, goes, remembering that this is ALL only Video. With this method, you still must use the AV, red & White, Audio, Inputs to get the "Sound" into the unit
First you need to know if your PC can output to a TV. Then you need to get the adapter & cables that connect the PC to the TV. Then you need the correct TV drivers installed for your video card. When they are all installed, you need to "Enable" that Monitors, the TV's, Desktop. You need to set either a "Cloned" display or "Spanned, Extended Desktop". Go to "Display Settings" Now ensure the TV/Monitor connected has the correct input/output display settings. Adjust the screens resolution via the resoloution "Slider", it is best to start with, 800x600 32 bit color. or even lower. and once working OK, THEN increase to max resolution, your TV can handle, find out from manual. Once it is all connected up. It should all just work great. Now, from then on, &, to get it to work every-time, the process is. Turn everything OFF. Connect the leads between PC & TV, Turn the TV, ON. Then, startup the PC up. It should "Detect" that it has TWO "Monitors" ie: One Monitor & One TV/Monitor, & you should see your desktop appear after a bit. Now you have screen 1 & screens 2. Now, if you are using "Cloned" mode, then whatever is displayed on the Master monitor, will be displayed on the TV. If you used Spanned, mode, in this mode, however, you will have to."Drag" the Video window, over to the TV, and it is though, you have one "Big Desktop". Now IF using Nvidia or ATI then BOTH of those have thier OWN, Control Panel, this, all then can make it all a lot easier to do it. So I would suggest that this method be used. But if you get stuck, or just want to do it by hand, then the the "By Hand" method is the only way.There is a great program called MultiMon, this allows great control over dual displays, and is well worth installing.
Connecting this up will be easy. What you do is get a yourself a set of the right, for your setup, cables. That uses EITHER one of the formats, of these described, below. You will need, either, a THREE way Cable, or three separate " Coaxial Cored" Cables with RCA PLUGS on them. Colored Yellow, (Video) Red, & White. (Audio) AV. OR If you haveSCART Connection Sockets, it's a big Black Socket at rear of unit(s), you get a SCART Cable.& It's all inside. Now some units, use a standard called Component Video, that uses, a Green, Red, & Blue Plugs. Also we have with the "Component Video" it is marked "Y" "Pb" & "Pr" these simply go color to color at BOTH ends, this is where the Red, Green, & Blues, colored Ends, of the Wires, goes, remembering that this is ALL only Video. With this method, you still must use the AV, red & White, Audio, Inputs to get the "Sound" into the unit, with the Component setup, you will also ,need, Two more Cables, for the AV Audio. these are, Red &White.(So with Component Video there are 5 Cables/Plugs in all). In any event ALL Cables go Color to Color, at each end, plugging into the corresponding Colored RCA Jacks, on either machine, or VCR or TV. Now if you have SCART, then it simply plugs in only one way. It is that simple. So connect up with the leads your set uses, and select the correct "Input" from TV/Remote, it is NOT on a "Channel" it will be on AV, AUX, and Press "Play" on VCR/DVD whatever.... should be all go.
Mar 21, 2010 | Vizio VU32L 32 in. HDTV LCD
Hi I have a Philips 32inch ambilight TV about
No a lot of HDMI does NOT send the sound signal through the HDMI cable & must be run AV to AV, the RED WHITE & YELLOW plugs Color to color for RED & WHITE, the YELLOW is Composite Video. . The SCART should indeed have it "All in one" however that signal is only RGB, or Composite Video, a lower quality, than HDMI. Just use HDMI & AV. you'll be all good.
Feb 06, 2010 | Televison & Video
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
