SOURCE: I want to change from kilograms to pounds how do i
2.2 is your factor.
Multiply by poundsx 2.2 = kgs
Divide to get pnds.
SOURCE: How do I change the scale to read pounds instead
Turn over the scale, on the bottom, there should be a little black switch that you can use to select between lbs and kilograms.
SOURCE: I can't figure out how
depending on the make and model, there may be a switch on the underside of the scale, or inside the battery compartment.
SOURCE: give me an example of code that convert pounds to
Pounds to Kilogram - multiply by 0.4535924.
Example: 2.5pounds to kilograms = 2.5 x 0.4535924
= 1.133981
Kilogram to Pounds - divide by 2.2046224
Example: 4.32kilograms to pounds = 4.32/2.2046224
= 9.325553
SOURCE: how do I convert butter,
1 kg is about 2.2 punds. To convert from pounds to kg you must divide by 2.2.
1 pound=1/2.2 kg = 0.45454545 kg. To convert from kilogram to pounds multiply by 2.2
