SOURCE: Ice Maker will not release the frozen ice cubes from tray
The icemaker use an avaporator system with an heatinc coil and a fan to release cubes.
In your case either the heating coil or the fan in the icemaker must be replaced.
parts can be purchased from partselect.com.
SOURCE: Ice maker quit dumping ice to the tray
You have a bad icemaker thermostat ( replace the whole icemaker ) or the temperature is not at least 5 degrees cold . You might check your coils to make sure they are clean (usually at the bottom from the front of the fridge ) only vacum or brush what you can get to as this will also keep the icemaker from harvesting .
SOURCE: ice maker not ejecting ice and then tries to fill tray and leaks
The Ice Maker Tray had a small plastic piece break off. This piece aids the tray in bending to dislodge the ice from the tray. Bosch does not just sell the tray, you will have to buy the whole ice maker assembly. You will need to order Part # 0422 from Bosch. I was not very happy about having to spend $112.00 for this whole assembly when all I really needed was a simple ice cube tray.
Save the $112 and remove the ice maker. Buy Ice at the grocery store.
SOURCE: Bosch Evolution B20CS50SNS about two years old. No
I've had lots of problems with my Bosch refrigerator ice maker. The ice tray has a tab on the back corner that twists the tray when it cycle to empty the ice. That tab broke off and when I looked into replacing the ice tray the authorized Bosch dealer said the tray is only sold with the complete ice maker unit. Sells for about $160. I have a hard time spending $160 for another complete ice maker when I only need a $10 replacement ice tray. This ice maker is sub-par for an appliance name brand like Bosch.
SOURCE: Frigidaire Ice Maker not working
I have a Frigidaire side by side refrigerator freezer MRS20WRGW0. I had the thermostat-defrost replaced yesterday. Now the ice maker isn't working, doesn't have water in the "tray" part that makes ice, but does still dispense water through the door. What could be causing this problem?
Kenmorw 795.7130 Bottom Freezer
