Question about Asrock AM2NF6G-VSTA Motherboard
Boot problems, erratic behaviour
I experienced many boot problems with that motherboard : when I push the ON button, sometimes it works fine, sometimes the fan does one or two turns, sometimes nothing, very erratic behaviour.
does anyone have experienced such a problem ?
Thanks in advance
Fanch (excuse my english, I'm french...)
Re: boot problems, erratic behaviour
Even I am having the same problem.
The solution given is not working.
I tried with many of the options but everything in vain.
Plz provide a solution for this.
Posted on Aug 05, 2008
  • 238 Answers
Hi, check for the foll. issues..BIOS not configured or bad,(Check Lithum Battery),or bad ram module, check if the SMPS itself is bad,less likely that the MOBO is bad.
Posted on Dec 15, 2007
0 characters
3 Points
Want boot up. Whern you push the power on button, one light on the CPU comes on and all fans come on. There is one beep when you push the button. The CD drive has power. The moniter does not come up. I...
it means machine working fine but display problem check it your RAM check with a soft cloth may monitor is also avilable or check behind the VGA cable proper connect it or not
Sep 23, 2011 | ASUS P4P800-VM Motherboard
I had an intel d865 perl motherboard with a 2.8 processor and 4 gigs of ram, computeer ran great for years then one day i shorted the motehrboard and fried it, i ordered a brand new one and installed it...
Thanks for asking FixYa for help. My name is Jeff and I will be assisting you today.
If you are using the same motherboard as the first one, what you are experiencing is too weird to worry over. Is it still under warranty? I'd say you have proved that the MB is deffective. Take it back for a refund or exchange.
If you are in need of additional help, please let us know.
Thank you for allowing us to help you today.
Jan 19, 2011 | Intel D865PERL Motherboard
Erratic video display problems; sometimes flickery, sometimes diplays rubbish, sometimes no display at all. Restart PC, sometimes back to normal, but after awhile problems come back. Should i replace the...
If you use the integrated VGA try to update drivers from here
if this doesn't solve you're problem get a new VGA card for PCI Express,
and since the motherboard has an nvidia chipset you should get an nvidia grafic card.
Jan 09, 2010 | ASUS M2N68-AM SE2 Motherboard
Erratic behavior - system halts with blue screen with error codes
sounds like serious memory errors. download and boot to "memtest86" to terst your ram for errors, but it may also be the memory controller.
you can try also to swap slots between the memory sticks and see if it works better with the sticks swapped.
Oct 15, 2008 | EliteGroup KN1 SLI Extreme Motherboard
Bios problem
simple. get the board over to a friend. Be careful with this step now..
loosen the bios on the friend's motherboard so that it just touches the contacts and once it boots into a dos mode swap it with your bios and flash the correct one. remember to be very very careful about how you insert the bios chip.
it works as i have done it for my old k8v-vm ultra
Aug 22, 2008 | Intel Motherboard
Toshiba 400cs does not boot
Removed battery and plug in AC cord. Unit booted up and ran fine.
Apr 22, 2008 | Toshiba Refurbished SYSTEM BOARD 400CS...
Problems with intel D850GB motherboard
There's nothing obvious here, so you need to start with the basics.
Look in Control Panel/Admin Tools/System and Application to see if any errors suggest a fix.
Be sure the old (New) graphics driver was removed.
Clean out any dust.
Remove all components and replace them one at a time carefully making sure you get a good connection each time.
Power up the board as you replace each item to see if you can isolate the error.
Dec 01, 2007 | Intel Motherboard
Computer powers off during boot
Hmmm...try resetting CMOS & checking all external peripheral connections: (KB/mouse, monitor, etc.)
Oct 26, 2007 | ASUS A8N-E Motherboard
Asrock AM2NF6G-VSTA Motherboard Logo
111 people viewed this question
Top Asrock Motherboards Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
Are you an Asrock Motherboard Expert? Answer questions, earn points and help others
