Washes fine will not spin and drain - Washing Machines
  • StanStihl May 11, 2010
    There are a few things that can cause this... on top loaders, the first thing you should check is the lid switch. Different models put this switch in different locations, and use different methods for activating the switch (some are magnetic, some are activated by a tab on the door, and some are activated with the door hinge. On front loaders, this is usually caused by a blockage in the drain pump. Model number stickers are usually located somewhere inside the door area on either type, or occasionally behind the control panel.
    Brigadier General:
  • 3,513 Answers
One of the main reasons for the washer not to spin or drain is the interlock switch. Top load washers are designed with an interlock switch that stops the machine if the lid is opened during a spin cycle. This switch is operated by a post mounted on the lid that goes into a hole in the rim of the machine and pushes down on the switch, or a bump on the side of the lid right by the hinge that presses against a switch when the lid is closed.
Determine which type you have. If it is the type with a hole and post, get a screwdriver and stick it into the hole with the machine in the spin cycle and the knob pulled out. If the machine starts, then the post is missing or broken.
If you have the other type of door interlock then the switch may not be working, but you will need a service call to fix it.
Would appreciate if you mentioned the model number of the washer.
Thank you for contacting www.Fixya.com
Posted on Jul 27, 2009
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Miele washing machine wont spin or drain
clean your filter first then check there is nothing in the pump area
Jan 22, 2014 | Miele Washing Machines
Washing machine wont drain
Does the washer spin when in spin cycle ? If it does spin and there is no water coming out of the drain then you most likely have a bad wa
Aug 07, 2012 | GE Washing Machines
Kenmore 80 Series Washer is not draining. Worked fine for first wash last night, but did not drain on the second. Anything that can be done by us to check this problem?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 25, 2011 | Kenmore Washing Machines
Maytag performa PAV2300AWW does not spin (wash cycle works fine). During the spin cycle the tub does not rotate...but i can hear the motor running...water drains...Pls help
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Aug 29, 2010 | Maytag PAV2300 Top Load Washer
Front loader won't spin, but it washes fine, drains fine
CHECK THE MOTOR. IF MOTOR GOOD, REPLACE MOTOR CONTROL BOARD.
BOYNISMO@YAHOO.COM OR 714-334-1998
Nov 27, 2009 | Frigidaire Washing Machines
Washer won't spin and drain
Sounds like your drain poump is failing. It's spinning lighter loads but not able to take a full load. I woule definately replace the drain pump,
Feb 28, 2009 | Frigidaire Washing Machines
Washer wont spin or drain
did you check to see if there was anything stuck in the pump? sometimes socks and other small articles get dow there and wont allow the washer to spin or drain
Feb 07, 2009 | Frigidaire Washing Machines
Whirlpool washing machine not draining.
Hi thanks for te question. the lid switch is more likely to have failed ,because no drain or spin. check that.
Oct 07, 2008 | Washing Machines
Washing Machines Logo
142 people viewed this question
Top Washing Machines Experts
