Question about Sony Playstation 3 (PS3) Console
What is the wep key for linksys - Sony Playstation 3 (PS3) Console
It's the password you need to access an wireless network .
Posted on Jul 27, 2009
Tip
How to set up WEP on Linksys Router
Setting-Up 152-Bit WEP Wireless Security on a Linksys Dual-Band A+G Wireless Router
Question
How do I set up 152-Bit WEP on a Linksys Dual-Band A+G Wireless Router?
Answer
Wired Equivalent Privacy (WEP) can be a 64-bit key with 10 hexadecimal digits, a 128-bit WEP key with 26 hexadecimal digits or a 152-bit WEP key with 32 hexadecimal digits. This encryption will prevent other users from connecting to a wireless network using your own WEP key. It will also protect your wireless transmissions/communications from being accessed or received by other users.
NOTE: Make sure to change the wireless settings of either Wireless-A or Wireless-G depending on the standard your network is using.
152-bit WEP key only applies to 5GHz 802.11a Wireless enabled network.
To setup WEP Wireless Security on your Linksys router follow the steps below.
Setting-Up the Linksys Router to use WEP
Step 1:
Access the router’s web-based setup page. For instructions, click here.
Step 2:
When the router’s web-based setup page appears, click Wireless then click WirelessSecurity.
Step 3:
Look for SecurityMode and select WEP.
For Wireless-A Settings:
4439-001.pngFor Wireless-G Settings:
4439-003.pngNOTE: If the screen on your router’s web-based setup page looks different, click here.
Step 4:
Look for the Encryption drop down menu and select 152 bits.
Step 5:
Look for Passphrase and type a wireless network password of your choice, then click Generate. In this example “MySecretKey” was used.
NOTE: You should come up with a password that is unique for your network and is a combination of numbers and letters up to 16 characters.
Step 6:
When you click Generate, the result will be a string of random characters.
Step 7:
Look for TXKey and select any number to determine which key you’ll be using. In this example, we selected 1.
4439-005.pngStep 8:
Copy Key1 since 1 was selected under TX Key.
NOTE: Do not give this key to anyone. This will be your wireless network’s key.
Step 9:
Click 4058-005.jpg.
© 2010 Cisco Systems, Inc. All rights reserved.
on Feb 26, 2010 | Computers & Internet
I want to encrypt a wireless network with wep
Question
Answer
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Step 7:
4439-005.pngStep 8:
Step 9:
Click 4058-005.jpg.
Feb 26, 2010 | Linksys Wireless-G WRT54G Router
Dont know my wep key
Connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1 or
http://1921.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
then go to wireless security.
You find there wep key but you need to set new key becasue it is * or # format.
Then set new key then save settings and restart router.
Let me know if you need more assistanse.
Thanks.
Aug 26, 2009 | Linksys WCG200 Wireless Router
Not sure of my WEP key on my BEFSR41 linksys router
The only way to see your WEP key is to remote into the router. Open a browser window, enter 192.168.1.1 in the address line and hit enter. When asked to login the default login is:
UserID: admin
Password: (nothing - as in do not enter anything)
IF this has not been changed and you get in, click on the wireless tab and you should find your wireless key there.
Good luck
Apr 10, 2009 | Linksys EtherFast Cable/DSL Router
Configration wireless linksys
Hi
I would suggest you use WPA instead of WEP if possible.
If you must use wep use 128bit or better.
13key acii example
dbct48v89h1e3
Feb 02, 2009 | Linksys Wireless-N WRT150N Router
Don't know WEP key
Type in 192.168.1.1 in a browser page. A login box will open up. You will need to put the password in . If you have not set a password, then the default is admin. Leave the user name blank.
when the Linksys setup page opens, click on wireless, then on security. you will see your WEP key there.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 03, 2009 | Linksys Wireless-G WRT54G Router
I am needing the key or WEP to re-connect to wireless
If it was not setup with a WEP key then try "admin" that is the password for Linksys when not set up. The purpose of the WEP key is to install a password to type in before anyone can use your network. So if "admin" does not work then you have to ask the person who set up the Wireless Network what the WEP key is.
Jan 02, 2009 | Computers & Internet
Wep key
You need to remove the wep key from the linksys configuration
to enter the configuration of the router, in Iexplorer, go to http://192.168.1.1
there must be a security access confguration than refer to wep active/inactive
switch it off, it should go.
Nov 20, 2008 | Computers & Internet
Securing wireless router
Click here for a link to the instruction manual. All this was retrieved from p.48
First off make sure your wireless connection is working
1. On the Setup tab of the Router’s web-based utility, click the Enable radio button next to WEP. Then click the Edit WEP Settings button.
2. You will see the 2.4GHz, 54g, Wireless-G (WEP) screen (Figure C-1). Next to Default Transmit Key, select which WEP key (1-4) will be used when the
Router sends data. Make sure the receiving device is using the same key.
3. For the WEP Encryption drop-down box, select the level of WEP encryption you wish to use, 64-bit 10 hex digits or 128-bit 26 hex digits. Higher encryption levels offer higher levels of security, but due to the complexity
of the encryption, they may decrease network performance.
4. Instead of manually entering WEP keys, you can enter a Passphrase in the Passphrase field. This Passphrase is used to generate one or more WEP keys. It is case-sensitive and should not be longer than 16 alphanumeric characters. (This Passphrase function is compatible with Linksys wireless
products only. If you want to communicate with non-Linksys wireless products, enter the WEP key manually on the non-Linksys wireless products.)
After you enter the Passphrase, click the Generate button to create WEP keys.
Note: All Wireless-G and 802.11b devices in your network must use the same Passphrase or WEP key.
5. WEP keys enable you to create an encryption scheme for wireless LAN transmissions. If you are not using a Passphrase, then manually enter a set of values in each Key field. (Do not leave a key field blank, and do not enter all zeroes. These are not valid key values.) If you are using 64-bit WEP encryption, then the key must be exactly 10 hexadecimal characters in length. If you are using 128-bit WEP encryption, then the key must be exactly 26 hexadecimal characters in length. Valid hexadecimal characters are “0”-“9” and “A”-“F”.
6. Check all the values, and click theApply button to save your WEP settings and return to the Setup screen. To cancel any changes you’ve entered on this page, click the Cancel button. To get more information about the features, click the Help button.
Jun 15, 2008 | Linksys Wireless-G WRT54G Router
Sony Playstation 3 (PS3) Console Logo
103 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
