Question about HP Officejet 5610 All-In-One InkJet Printer
Printer wont work
My printer says its out if paper when i just loaded a lot and it wont print
  • 21 Answers
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
djiu9ofdfd26
Posted on Sep 06, 2009
Kyocera 2020d WONT PRINT Load Mp Tray
load a4 paper in bypass or the mp tray as it is also called
Jun 08, 2017 | Kyocera FS-2020D ECOSYS Monochrome Laser -...
My printer is working but notting is printing on the paper
1st check ink cartridges if its a new printer the ink heads will be taped if so then it wont print. run the print heads program to set and align the heads. when donr it will print out a paper with lots of **** but thats ok now its set up to print. run the disk it came with to load it to computer. make sure that the printer your are using is the one that is marked on your computer to use. under start pick printers and select from there. add paper in the slot and make sure all openings are open on the printer. it should work fine.
Mar 30, 2011 | Canon BJC S500 InkJet Printer
I have a Dell 3000cn printer it is saying load paper but the paper is loaded but wont print
check whether the cartage is fix well or the paper is far from the area from where the printer starts printing.
Jan 27, 2011 | Dell 3000cn Laser Printer
My printer says load paper then press start, I have paper in there and it wont print.
Dont know what you have already tried but first off verify that you are loading paper to the correct tray. Now this tray is going to have a switch located toward the feeder that tells the printer paper is loaded make sure the paper is back far enough but not to the point where you are forcing the paper into the feeder. If all this still doesnt work try reseting the printer and printing a test page. Hope this helps.
Mar 10, 2010 | Dell 924 All-in-One InkJet Printer
Printer wont print. It keeps saying PC Load Legal. The printer has paper in it.
Well the printer is telling you to load "Legal Size paper, which is 8.5" X 14" paper.
More than likely, the application you are using is telling the printer to print the page on legal sized paper.
If you want the document to print on "Letter sized paper (8.5" X 11") then in the application, go to the File drop down and select "Page Setup". From within page setup's window, change the paper size to letter and then re-print the job.
Don
Dec 16, 2009 | HP LaserJet 4 plus Printer
Printer says paper jam, now scanner wont work
you will need to open it to remove this piece of paper.
Aug 14, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Canon MP600 all-in-one printer.Out of paper?
Try this:
Go into the driver toolbox under printing preferences and select auto
continuous feed from the paper source dropdown box.
Both trays should be of the same size paper and type for this to work.
Jul 10, 2009 | Canon Pixma MP500 All-In-One InkJet...
Canon Mx300 wont recognize my paper. says:load paper
I cant print...orange light under alarm keeps flashing...please help...patricia
Jun 04, 2009 | Canon MX300 Office All-In-One Printer
Paper won't load. and Stops printing before it can start.
Try turning the paper around. Some times the corners of the paper get slightly bent and the paper wont load.If turning the paper around does not work, switch your paper. Hope this helps.
Feb 03, 2009 | Canon PIXMA iP1600 Printer
Problem with Dell 725 Printer
We have the same problem. It seems to help if you load a lot of paper
Oct 07, 2007 | Dell 725 InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
79 people viewed this question
Seeker5211
Seeker5211
