Question about Canon i350 InkJet Printer
MP360s Colour prints not correct. Cartridge replaced and ink present at cartridge red yellow blue. Yellow prints ok red not very red no blue at all. Colour print not used for some time, deep cleaning carried out numerous times to no avail. Cour print incorrect whether print from PC or internal scanner.
  • 103 Answers
Re: MP360s
Hope this will give you hints. To pin point directly you need to replace printer head. But before replacing please consider suction cartridge caps or nozzle by cleaning and freeing clogged airways by dettaching manually. I understand that the long time being not used has caused the problem. However if you can still use black and other colors then used it than complicating downtime in repairing procedures. Yes, you are right no need to clean deeper more than three times it will consume inks half empty. Have a nice day.
Besr regards,
Rosener Guyano
Posted on Feb 06, 2008
0 characters
3 Points
Blue colour is missing from colour cartidge
Something may have gotten stuck in the blue ink and clogged it. If the cartridge is new you may be able to send it back and get it replaced, If not you may just be out of blue ink.
Aug 04, 2013 | Lexmark X1270 All-In-One InkJet Printer
This issue will only occur if an ink cartridge(s) is or was installed inthe wrong position (slot) in the machine. When a cartridge is installed, the ink tube system is filled with the ink from the cartridges, to prepare the machine for printing. If the cartridge is inthe wrong position the tube will fill with the wrong color.
NOTE: If you just installed or replaced the ink cartridges and your printed documents are missing colors please refer to the solution - I just installed or replaced my ink cartridge and my printed documents aremissing colors. What can I do? Blank
To resolve this issue you will need to clean the print head.
NOTE: It may require 10 to 15 cleanings to clean the ink tubes and print head. During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to completethe cleaning process.
1. First verify the position of the ink cartridges:
a. Open the ink cartridge cover and check to make sure the ink cartridges are in the correct order.
b. Starting from the left side, the correct order is Black, Yellow, Cyan(blue), and Magenta (red).
- If the ink cartridges are installed in the correct order, close the ink cartridge cover and continue to STEP 2.
- If the ink cartridges are not in the correct order, remove the ink cartridges that are installed in the wrong position by pressing down on the release lever(s), located above the ink cartridge and remove the cartridge(s) from the machine.
Next, reinstall the ink cartridge(s) in the correct position in the machine by gently pushing the cartridge in until it clicks.
When all the cartridges are installed, close the ink cartridge cover.
2. After closing the ink cartridge cover, the LCD will prompt - Did youchange XXXX (XXXX = the color) This message will be displayed for ink cartridge that was removed. Press the - (Minus Key for No). This willkeep accurate data of how much ink is left in the cartridge.
1. Press the INK key.
2. Press OK to select Test Print.
3. Press OK to select Print Quality.
4. Press the COLOR START key.
5. Review the Check Sheet. The colors on the Check Sheet should be in a specific order: Black, yellow, Cyan (Blue) and Magenta (red).
a If the colors on the Check Sheet are in the correct order and are notmissing any dashes, press + (Plus Key for Yes) on the key pad and continue to STEP 7.
b If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - (Minus Key for No) on the key panel and continueto STEP 6.
6. The machine will need to perform cleanings to flush out the incorrectcolor or dried ink from the ink tubes and print head.
a. The LCD will ask you BLACK OK. If black is fully printed and is the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
b. The LCD will ask you COLOR OK. If any of the 3 colors (yellow, cyan (blue), and magenta (red) are fully printed and are the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
c. The LCD will say START CLEANING + for YES and - for NO. Press + for YES to start cleaning. The machine will go through a cleaning cycle that will take approximately one to two minutes.
d. After the cleaning is completed, the LCD will say PRESS START. Pressthe BLACK START key. This will print out the print quality check sheet again for you to check and see if your print quality issue has been resolved or not
NOTE: If you wait 1 minute after the cleaning cycle is completed, the display will return to date and time. You will need to go back to STEP 3 to print the Print Quality Check Sheet again.
e. If the ink color order is correct and all of the dashes are present, press + on the key pad to select YES and continue to STEP 7.
If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - key to select NO. Repeat the cleaning process byfollowing STEPS 6a through 6d. You may have to perform this procedure up to 15 times in order to clean the ink tubes and print head
NOTE: During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to complete the cleaning process.
7. Test by printing the document that had the reported problem (wrong color printing).
Dec 08, 2010 | Brother DCP 165C Compact Color Inkjet...
HP5550 printer is printing everything in green. We have true HP cartridges
So, your "blue" and "yellow" ink-cartridges are OK, and are mixing to produce "green".
But, either your "red" ink-cartridge is empty, or the ink-jets that shoot that colour onto the paper are BLOCKED.
Run a print-head-cleaning-cycle, using the HP Support Tools that were installed from the HP CD-ROM, and then, if necessary, replace/refill the "red" cartridge.
Aug 30, 2010 | HP DeskJet 5550 InkJet Printer
I have just fitted new cartridges although it was only the colour one which needed renewing I thought! However it wuld only print out in red/pink shades so I changed the black cartridge to be on the safe...
I have personally encountered similar problem in my work. There is no problem with your printer, No need to go to your suppliers yet.
Sometimes when either of the inks overflow at the nuzzle, it gets absorbed to an extent into another ink compartment. So that colour affected now prints another colour; the colour that has crept into its compartment, Sometimes it is serious at other times is not. If not serious, usually, after a few solid colour prints the colour affected returns to normal.
I do not know how much of a technical person you are, but I will give you the solution to returning that yellow printing red back to printing truly yellow. Bring out your colour cartridge. Peel off the seal covering top. You will see the holes through which in is fed into it. Get a clean handkerchief, fold it and place over the top of the cartridge. Hold it over a bowl or something. Now place your mouth over the top with the handkerchief in between and blow hard. Ink will discharged at the nuzzle. Clean off the ink. (At the nuzzle do not rub only dab). Now press a piece of folded tissue to the nuzzle firmly. It should be blotted with ink:- red, blue, yellow. If any colour is missing you may need to repeat the procedure. Once you get the three colours back, the issue is resolved.
Dec 06, 2009 | HP PSC 2355 All-In-One InkJet Printer
Your problem is not of specially cartrigde but what you need is a special Paper which is made to print Photos and other colour full pictures. If you see is not this problem then there is chance that your cartridge is leaking from blue color point as there are three inks in color cartridge Red,Blue and yellow , than you need to replace you colou cartridge with new one .
Aug 28, 2009 | Printers & Copiers
Print colour is off
Sounds like you have cyan and magenta ink but no yellow. (You need yellow to get yellows, greens, reds and orange shades.) First try running the printer utility to clean your ink jets, then run a test print. If this does not work then simply replace the yellow ink cartridge.
Aug 27, 2009 | HP Photosmart D5360 InkJet Printer
The printer prints really red
It's probably the Colour ink cartridge is gone. Best off replacing the colour ink cartridge...more than likely the blue and yellow are run out.
Nov 08, 2008 | Printers & Copiers
download the utility ssc service from the site and use the power cleaning option
Aug 14, 2008 | Epson Stylus Color 640 InkJet Printer
Printing error (Canon ip1800)
replaced ink cartridges..error message appears now telling me to re align printer..can you tell me how to do this
Jul 08, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon i350 InkJet Printer Logo
95 people viewed this question
Top Canon Printers & Copiers Experts
old marine
old marine
Are you a Canon Printer and Copier Expert? Answer questions, earn points and help others
