Question about Sanyo 4.4 cu. ft Counter-High Refrigerator, SR-4433S
New compresor on ,but refrigerator hot?????
  • 27 Answers
Sounds like gas loss to me
Posted on Jul 29, 2009
Whirlpool sise by side fridge mod # ED5FHEX5SNOO Whirlpool side by side: --------------Fan running -------------------------Compressor not running (not clicking) --------------------Freezer ok, FRIDGE NOT...
YOUR SAFETY SWITCH IS CUTING OF. THIS SWITCH IS NEAR THE COMPRESOR. SHOULD COMPRESOR GET VERY HOT IT IS INDICATION THAT IT NEEDS TO BE REPLEACED. IN THIS CASE SOMETIMES IS BETTER TO GET NEW FRIDGE AS REPAIRES MIGHT COST TO MUCH
Mar 02, 2011 | Whirlpool Refrigerators
My refrigerator LG GM 313SC wasn't working yesterday, I disconnect the refrigerator and notice that the compresor was too hot, I reconnet the refrigerator at night and in the morning checked the compresor...
I have 2 of the LG GM 313SC. Purchased brand new here in the Caribbean (Dominica) Both units when I turned them on for the first time are making a 'clicking' noise that is happening together with blinking lights on the temperature control inside the fridge section.
It isn"t even turning on. The light inside is dim, which the manual says is an indication of a problem, and to call an electrician. I think not, they are brand new and behaving the same way.
Any suggestions
Oct 21, 2010 | LG Refrigerators
I was told that it needed a new compresor. but they said its cheaper to buy a new machine instead of the compresor because it would be cheaper
You need to get another opinion....there is no way a new compressor should be close in price to a new unit...your getting scammed...
heatman101
Aug 18, 2010 | Coldtech S3BRR-18S Commercial Refrigerator
Compresor is hot, have voltage, capacitor is ok
First unplug the machine. carfully remove the cover on the side of the compressor the get to the start device. Remove the start device. Once removed you will have 3 prongs from the compressor. Using a meter make sure you have continuity between each of the three prongs if you do not then the compressor is bad. If all check good then check each prog to the groud of the compressor or the case, if you have continuity then the compressor is bad. If you have passed both tests then you can try a new start device. after you replace the start device you will want to test the current draw from the compressor to make sure that it is not what is causing your start device to fail.
Note :The compressor is a sealed unit and its life can't be determined. puting a new start device on your compressor is a good idea and most of the time will solve your problem. But if your compressor is the cause of the problem it will only last about 30 days.
Jan 07, 2010 | KitchenAid KSCS25FKSS Side by Side...
Freezer not freezing, and the panel between the fridge and the freezer gets very hot
The condensor fan motor is probably not running. The condensor fan keeps the compresor cooled, if the compresor gets to hot, it shuts down until it cools off and tuns back on, but will not keep temp. Heat exchange lines go in the panel between the doors to serve as a heater so the doors dont freeze shut, but when the compresor overheats, so do those lines. That would be why that panel gets so hot. Both problems will be resolved with a new condensor fan motor ( located by the compresor).
Oct 16, 2009 | Estate TS25AFXK Side by Side Refrigerator
Everthing sunddenly thawed out how come? whats the fix can i do it my self
If you heard the compresor running and it's not cooling ,probably is out of refrigerant(freon) ,but ifthere's power in the outlet and the compresor isn't working and is hot to the touch ,could be the relay or the compresor went bad ,also if there's power but the compresor is cold it could be the thermostat is open ( you can check it by putting a jumper in the thermostat wires).
Aug 20, 2009 | Frigidaire Freezers
COMPRESOR GETS REALY HOT IS IT THE SWITCH BAD OR THE COMPRESSOR
Reasons for a hot compressor are:
  1. It is just hot and is not a problem.
  2. Lack of ventilation to compressor.
  3. System is short of refrigerant which prevents the return refrigerant from the cooler being cold enough to cool the comp.
  4. If system is short this could make comp run continuosly trying to reach temperature
  5. If the thermostat is stuck on the inside cooler will probably freeze up, so that shouldn't be it.
  6. Compressor could be "letting by", meaning hot gas goes into the cold side of comp, if that is if it will stop working eventuallly.
Hope that helps.
Aug 03, 2009 | Roper Refrigerators
Freezer or fridge stopped cooling. Can not hear compressor kick on
If the compresor is trying to start and it won't you 'll heard a click and the compresor will be very hot ,that means that the relay is bad or the compresor is stuck or burned and needs to be replaced, but first before replacing the compresor try with the relay (no more than $20).But if the lights and fan inside the fridge work and the compresor won't start and is not hot ,the problem is in the cold con trol (you can put a jumper wire between the two wires to the cold control and if the compresor starts thats your problem) after all this if still the compresor won't start could be that the timer is stock in the defrost position.
May 01, 2009 | Refrigerators
Fridge freezer not working/power ok,
If the compresor is very hot and won't start,the clicking you heard is the overload at the compresor that goes on & off beacause the relay ,that makes the compresor start is bad or the compresor is bad ,if you know how check the compresors coil if not try replacing the relay with a same replacement(no more than $20 or $30) if still won't start the compresor needs to be replaced.
Apr 24, 2009 | Refrigerators
Refrigerator continuously cycles
This is a generic problem with Whirpool refrigerators.The start relay for the compresor(located on the side of the compresor under the black plastic cover) is probably bad ,replace it(about $ 20) with a new one(write down where the wires go) that should solve the problem if not the compresor is bad.
Apr 15, 2009 | Whirlpool Refrigerators
Refrigerators Logo
110 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
