Question about Whirlpool LER5636P Electric Dryer
Whirlepool electric drier won't heat
It runs fine on all settings and the drum turns too. This is the model LER5636 EQ3 front loaded clothes dryer.
  • 6,784 Answers
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
OK, if the above checks out ok and, the vent is clear of obstructions, you will need to replace the element.
Posted on Jul 27, 2009
    Scholar:
  • 70 Answers
Heater element,
That's a new unit and should / very well could still be under service warranty and you should check to save time and cost.
However if not get your manual for access instructions. Unplug the unit and visually check to ensure it's { heater element } connection hasn't simply worked loose from moving the unit or fair wear and tear vibration { wear is unlikely with the unit being so relatively new }
If the element is connected and just not functioning to provide heat. Just replace it and it's inexpensive, easy to replace no special tools required and the only thing that isn't functioning.
Kenmore 110.82822102 Electric Dryer runs but no heat.
I think the heating element went bad. Depending on your driers layout, you might have to remove the drum assembly to gain access to the heating element. Once drier drum assembly is removed, check and see if there is 220 volts going to the heating element. If there is, heating element is bad, if no voltage detected, the switch in the control panel is faulty. If you're not comfortable trying to check this out on your next step, I don't blame you. A qualified appliance technician would be the better answer especially working around 220 volts. Hope this works out for you.
Mar 10, 2014 | Kenmore 83142 Electric Dryer
Make Frigidaire dryer model Gleq2152es1 is making a loud sqealing noise and the clothes getting hung in top of dryer.
mostly the noise your hearing is the drum running on the side of machine .the baering/bearings have collapsed in your drier . Most driers these days have the bearing encased in the outer drum and i mean molded to the outer drum . You cant replace them and the manufacturer doesn`t really want you to . Sorry about that = looks like a new drier for you .
Aug 13, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Dryer is Electric. spins clothes but no heat?
What is the setting on for example towels,check lint trap in back when dryer turns does the back of drum turn red,look through door and watch. If you still don't feel heat its the coil,It should be under warrenty.
Jul 26, 2010 | Frigidaire GLEQ2152ES Electric Dryer
My dryer runs but does not heat up or dry clothes. What could be the problem?
I have a Kenmore dryer and it runs but won't heat up and dry the clothes. I don't hear the ignition even turn over. Please help. I can't afford to buy a new dryer at this time.
Feb 16, 2010 | Kenmore 62602 Electric Dryer
Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 20, 2009 | Roper REX3614KW Electric Dryer
Dryer will not heat and will not turn off at the end of the cycle
I had the same problem with my whirlpool LER5636. It was a power problem. My circuit breaker was fried (one side delivered 120v the other 26v). The dryer itself was fine. Check the breaker, the dryer outlet, and the connections where the dryer cord enters the dryer.
I replaced the breaker and all was well.
Good Luck.
Dec 27, 2008 | Whirlpool LER5636P Electric Dryer
Hw120m washer/drier
Check if the dryer is heating, if it is not heating check the following There's no heat
Oct 16, 2008 | Hoover H130E Front Load Washer
My dryer is giving off a strong odor. Smells a little like rubber or metal on metal. It still works great. Is still getting hot and drying clothes. Can you help? Lg washung machine/dryer combo(front...
Sounds like drive belt or drum supports, if the drier is gas I would check it out, could cause a fire, if it is electric still check to make sure it is not rubbing on the electric heat element, or it could be full of lint which is catching fire during normal operation and melting or burning the belt or drum supports.
Nov 04, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Maytag Neptune W/D (Stacked) Drying Irregularly
Mj, 90% of the time long dry times are caused by a pinched or clogged vent. Other things that could be causing this are: cycling thermostat trips too soon, if your dryer is a gas model, weak gas valve coils, drive motor centrifugal switch not allowing voltage to the gas valve or heating element. Check the harness to the motor to make sure it is on tight. Catriver...post back.
Sep 25, 2006 | Maytag Neptune MLE2000A Front Load Stacked...
Whirlpool LER5636P Electric Dryer Logo
225 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
