Question about Car Audio & Video
Driver side speaker and sub woofer make an popping
Driver side speaker and sub woofer make an odd thump type of noise, but all other speakers in my car sound fine.
  • untame805 Jul 30, 2009
    thanks for the response,
    I tried a brand new speaker and it also made the same pulsing sound like a clack not so much a thump. when i tried the old one that was on the driver side to the one on the passenger side it sounded like new which threw me off. now i think it might be the head unit but all the other speakers are ok so...????? as for the sub, it is new. unless it has a defect.
  • 97 Answers
They could be blown try replaceing them and see if it helps
Posted on Jul 28, 2009
  • nicholas mcintosh Jul 30, 2009
    well it could be just the fuse in cd player itself its a 10 amp fuse try replacing it but that does seem weird also
  • nicholas mcintosh Aug 01, 2009
Trying to hook up a KLH sub woofer, S100ETH, PSW8-100 to a VCR reciever. Reciever has sub woofer connection but does not works on the KLH sub woofer. What is the problem ?
I suggest you go over your receiver set-up instructions. See if you need to set the receiver to acknolwedge the addition of the subwoofer. It should be in your receiver set-up steps. Just as a check, hook up one of your other speakers to the subwoofer lead to see if gets audio signal. I'm guessing the issue is your receiver settings.
Jan 06, 2015 | KLH Audio Players & Recorders
Jenson xr-500 sub woofer
do a "pop" test on the speaker with a 9 volt battery..
Dec 28, 2013 | Car Audio & Video
Where can I get a driver for my MLi 691H speakers? I am running XP.
The humming noise could be a earth loop problem.
This is caused by having the speakers/sub woofer connected to one power point and the computer connected to a different power point.
To eliminate earth loop problems, connect both the speakers/sub woofer and computer to only one power point. Connect all your equipment to one power point using a power board.
Apr 12, 2012 | MidiLand MLI-699 Computer Speakers
My sub make a strange noise. It doesen't work anymore.Tks.
Strange noises can come from your amplifier or the sub itself. The most likely cause of the strange noise is the speaker just before it dies! If you have been using the sub-woofer at high volume levels then you probably have damaged it. Try testing the sub-woofer using a multimeter(on ohms setting) it should give you a reading from 8 to 4 ohms. Sometimes they may give readings as low as 1 ohm. When testing the speaker/sub you should hear a soft scratchy, thumping or clicking sound. This indicates that the speaker may still be working. If you don't have a multimeter try a 1.5 volt battery (say a AA), DONT USE HIGHER VOLTAGE BATTERIES they may damage the speaker! You will hear a clicking, scratching etc sound from the speaker which may indicate that it is still OK. If the speaker seems OK the problem may be in the amplifier, which I suggest you bring to a professional repairer. When buying speakers and amplifiers make sure the power handling of the speaker is equal to or greater than the amplifier output power. This should stop speakers from getting damaged. Make sure the speaker and amplifier specifications are rated in the same manner ie RMS PMPO Peak. A 100 Watt PMPO speaker will not survive the output of a 100Watt RMS amplifier!
Feb 08, 2011 | Audio Players & Recorders
Will the woofer work without the other two speakers?
There is no point.
The woofer(sub woofer) just delivers the bass. You usually put the sub woofer out of the way under your desk.
Without the other speakers you would just get the thumping bass and no treble
Aug 30, 2010 | Yamaha YST-MS201 Computer Speakers
Sub-woofer driver rattle/buzz.
Bad news! It sounds like the coil is rubbing inside the magnet of the speaker! There's no cure, when the cone is warped it it knackers it up. Had the same problem some years ago with a Wharfedale speaker. Someone told me you can hit it on the part where the cone joins the magnet -with a hammer!
Anyway it didn't make a bit of difference! And the speaker was chucked.
Feb 09, 2010 | Polk Audio PSW150 Speaker
Dell MMS-5650 5.1 speakers not working
sounds like they are picking up interference. make sure they are grounded well.
Aug 19, 2009 | Dell 5650 Computer Speakers
Stopped working. I-trigue 3400
The stereo -jackbus is broken if your speakers won't work and your headphones are fine. The stereo jackplug holds a little switch at the back, which moves sideways if you connect headphones.
Solution is very carefully opening back end of stereo connector bus and reassembling the switch
Oct 24, 2008 | Creative Labs ITrigue 3400 2.1 Speaker...
Sub woofer making a screaching loud noise when powered on
The pop from other electrical items makes me think it's a ground problem but I am do not have a clue as to what type of setup you are running over there. Did you try a surge protector?Is it 110volts with a seperate ground wire?
Have you tried running a UPS?
Sep 26, 2008 | Logitech X-230 Computer Speakers
Bose acousticmass 15 sub-woofer making a noise
The sub contains the amp for the other speakers. But it sounds like the amp has a seriously damaged section and will probably have to be serviced by Bose.
Jun 24, 2008 | Bose Acoustimass 15 System
Car Audio & Video Logo
127 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
