My Westinghouse LVM-37w1 monitor has a weak power supply. It periodically pops off and has to be reset with a turn off/on. I got a new power board main assy 5600110382 from the Partstore.com but it was the computer board with video hookups, not the main power supply board. How do I find out the WH part number for the main power supply board? Any suuugestions on suppliers? Most all parts for this monitor are now listed as "not available" on partstore.com/
You can also call us @ 800-701-0680. We can surely help you with any repairs/replacements (only if under warranty) or any referrals you may need.You can also call us @ 800-701-0680. We can surely help you with any repairs/replacements (only if under warranty) or any referrals you may need.
You can't post conmments that contain an email address.
Hello, I can assure you it is the inverter board on this unit. The T-CON board (controller) will only mess with your picture in different ways but you the way you describe the symptoms it is for sure your inverter board. The harders part wil be to find some, you should probably look in www.shopjimmy.com, or www.invertercentral.com.
Hello, this model has two ribon cables that run from the t_con board to the panel, it sounds like you might have to replace one of them if not the whole t_con board. You can find parts for this at www.shopjimmy.com, I would recommend you taking this unit to a certified repair center if you are not atleast a bit technical because you have to did a bit deep in to the set for this one.
While that is possible, it seems a bit drastic. That being said, the only way we can truely respond with useful information is if you provide us with the make and model as well as a description of the problem.
