Canon MP600 will not accept paper we load and print after we press OK as instructef
    President:
  • 8,637 Answers
This may not help everyone that I send it to, but it is worth a try.
I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press
the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer.
The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Aug 27, 2009
Auto head alignment
#1 of 2
Carryout a Manual Print Head Alignment If Possible.
If the results of Automatic Print Head Alignment are not satisfactory, follow the procedure below to perform Manual Print
Head Alignment.
1 Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Cassette.
Important. You cannot print the print head alignment pattern if paper of size other than A4 or Letter is loaded. Be sure to use A4 or Letter-sized plain paper.
2 Open the Paper Output Tray, and then open the Output Tray Extension.
(1) Put your finger in the rounded indent of the Paper Output Tray and open it gently.
(2) Open the Output Tray Extension.
3 Press the Paper Feed Switch to select the paper source where you have loaded paper.
4 Select Settings on the HOME screen.
5 Select Maintenance, then press the OK button.
The Maintenance screen is displayed.
6 Select Manual head align, then press the OK button.
The confirmation screen is displayed.
Note. If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
7 Select Yes, then press the OK button.
8 When the Print Head alignment pattern is printed, select Yes, then press the OK button.
9 Look at the printout. From the patterns, select the most even, least irregular patterns for each column and input their numbers. Press the OK button.
(1) Select a column to input the pattern number.
(2) Use the or button to input the number of the pattern.
(3) Repeat the steps (1) and (2) until you finish inputting all pattern numbers, press the OK button.
Oct 08, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon MP600 all-in-one printer.Out of paper?
Try this:
Go into the driver toolbox under printing preferences and select auto
continuous feed from the paper source dropdown box.
Both trays should be of the same size paper and type for this to work.
Jul 10, 2009 | Canon Pixma MP500 All-In-One InkJet...
Canon pixma mp110 saying ''please load paper and press ok''
there is problem in the paper feeder gears of the printer.they r pulling the paper and then not able to forward the paper as they worn out or slightly cracked.so they needs replacement with deep servicing/cleaning from proper technician .it will be ok after that.
Nov 16, 2008 | Canon PIXMA MP130 All-In-One InkJet...
There is error message that there is no paper.
Duhhhhh, I was trying to print with the lower light on the printing icon for tray rather than the upper light. Silly me. Thanks for being there.
Campcrow
Nov 11, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Printer won't pull paper into printer
How long have you owned the printer. How long have you had this problem? Is the paper old? Sometimes storage of the paper causes humidity and can cause this problem. You might want to try newer paper or clean the rollers with some alcohol on a rag/cloth. If you need any other assistance let me know. If you have a moment to accept and rate my solution I would greatly appreciate it.
Thanks,
Lee
Sep 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Check the "Feed Switch" button on the control panel (below the ON/OFF button) to be sure the green light at the back of the picture is lit. If not, try pushing the button and then printing again. It worked for me and it was so simple!
Aug 22, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Does not print on paper
Experienced the same problem a few months back with my new MP600 .. had to take it to an authorised repair centre where they replaced the print head .. all good since
Daniel
Sydney
Nov 01, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
