Question about Lands Phones
We have two handsets, and neither will hold a charge, despite being in the cradle, with the charging icon lit up the whole time. At first one would charges, and the other not, now neither will hold more than one bar. Is it the connectrions or did both sets come with crappy batteries?
    Scholar:
  • 86 Answers
Hard to say. How old are they? Are you bad for leaving the phones off the chargers for long periods? Letting the batteries run all the way down before charging again? These days its cheaper to buy new phones than it is to buy replacement batteries. But yeah, sounds like the batteries are shot.
Posted on Jul 27, 2009
    Scholar:
  • 70 Answers
Sounds like the handsets work fine aside from inability to hold a charge.
Which to remedy that it sounds like the factory shipped the product with el cheapo batteries that needs replaced.
I'll not degrade brand names here but it's became a quiet common issue lately.
Handset 2 which is doc upstairs goes dead as soon as you want to use it
It's time for a replacement battery. Cordless telephone batteries can be purchased at most places that sell cordless telephones, or battery stores such as batteries plus.
A test for this is that you can swap the batteries with handset 1 and see if the problem follows the batteries.
Does it appear to be charging when on the cradle?
Attempt to charge Handset 2 on the charging cradle you have for Handset 1.
Good Luck,
Mark
Apr 02, 2011 | Panasonic Lands Phones
Can the phones be left in the chargers continously?
Yes....in fact it's best to return the handset back to the cradle after use.
This is what Uniden says about battery life.
(With average use, your handset battery provides more than ten hours of talk time and approximately seven days
of standby time. You can achieve optimum battery life and performance by returning the handset to the base or
charging cradle after each use. When your handset is left off of the cradle, the battery will gradually discharge even
if the handset is not being used. The actual talk time duration will be reduced in proportion to the amount of time the
handset is off of the cradle.)
Nov 13, 2010 | Uniden DECT 6.0 Cordless Telephone...
Setting up my outgoing message: just purchased Uniden cordless DECT 1580. Manual says select command 8. How do I find Command 8? thanks, joan
please follow the instruction to register the handset to base
To register a DCX150 accessory handset:
1. Charge the handset completely.
2.Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
3.When the handset has registered to the base, the LCD will display Registration complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
To register a DCX200 or DCX300 accessory handset:
1.Charge the handset completely.
2.Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding find until the charge LED starts to blink.
3.On the handset, press and hold # until the handset beeps and displays Handset Registering.
4.When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
Thanx
Jul 21, 2010 | Uniden Cordless Phone
Battery works. Won't turn on
I have the exact same phone and exact same problem. Phone is charged in cradle and green light (indicating full charge) is lit on handset. Opened it up and everything appears clean as a whistle. Did the original poster find a solution? if so, please post it. Thanks.
May 27, 2010 | Panasonic KX-TD7896 Cordless Phone
Plantronics cs50 head set with lifter has STATIC
Try a system reset:
1.  Lift the headset off of the charging cradle, but make sure the headset is turned off.  It will be off if the green light on the front of the base is not lit.  If it's not, push the call answer button once to turn it off.
2.  Push the call answer button and the mute button at the same time and hold them down.  The mute button is the black little wheel at the top of the headset.  Use the tip of your finger to push it straight down and hold it while holding the call answer button.  A green light on the headset will flash for 2 series of flashes.  Wait until the end of the second series then let go of both buttons.
3.  Put the headset back on the charging cradle and wait 30 seconds.  Lift it back up and try to use it.  If this doesn't work, repeat one more time and then disconnect the power from the base and plug it back in.
Apr 24, 2009 | Plantronics CS50 Wireless Headset
I have a bt synergy 2110 cordless phone. There are 3 lights on the right hand side. one for power/in use, one for charging one for new call . All3 are lit up. How do i get the "new call " light to go out...
I may have a solution you can try.
1. Take handset out of cradle.
2. Press and hold bottom, right hand side, bottom button, marked "Calls"
3. Hold until "Display" shows number of calls, usually 10 and makes a bleep-type noise.
4. Now press top left button, marked "Del" in red, until the display scrolls through all 10 numbers and deletes all the numbers stored in the memory. The phone should then make a bleep noise.
5. Press "red handset symbol" (finish call) twice.
6. Replace handset onto cradle and the "new call light" should go out.
You should now be able to make calls.
Good luck !!!
Nov 27, 2008 | British Telecom Synergy 2110 Cordless...
VTECH VT9121
voice message light keeps blinking
Aug 25, 2008 | Vtech 9009111 Cordless Phone
Handsets won't hold charge and have no base subscription
smash it into little pieces! That's what I'm doing with mine.
Mar 26, 2008 | AT&T E2562 Cordless Phone
I have a Panasonic KX-TG6051CM
I had the same problem, and it seems that the battery charging circuit in the handset had locked up, constantly charging the battery until it overheated. I was able to reset the circuit in my handset by completely draining the battery. Here is the procedure:
1. Remove the handset from the charging cradle, and leave it on for a few days until the battery runs out, and the handset finally turns off. At his point, the battery will be very low, BUT NOT COMPLETELY DRAINED.
2. Next, you must manually drain the charge remaining in the battery by shorting out the two contacts on it. Shorting won't damage the battery, since it is holding very little charge at this point. An easy way to physically do this is to remove the battery, and place a piece of thin wire across the the two contacts of the HANDSET. I am referring to the contacts inside the handset that connect to the battery, NOT the contacts on the bottom outside that connect the handset to the charging cradle. Next, put the battery back in, sandwiching the wire between the battery's contacts and those inside the handset. This will hold the wire in place. DO NOT PUT THE HANDSET BACK INTO THE CHARGER, WITH THE BATTERY SHORTED OUT.
3. Wait about 30 minutes for the battery to completely die. Remove the jumper wire, and but the handset back into the charger.
4. If the battery was fully discharged , you will get a message on the handset telling you that you should let it will charge for 7 hours. If you do not get this message, then either the battery was not fully discharged, or your problem is different from mine. Try the procedure again in Step 3 for another 30 minutes to discharge the battery some more.
5. If you get the "Wait for 7 hours to charge" message on the handset, then leave it in the charging cradle for the 7 hours requested. After that, it should work fine.
Let me know how you make out.
Mar 24, 2008 | Panasonic KX-TG6051M Cordless Phone
My handset won't charge
Try charging it in a different cradle if you have more than one handset.  This has happened to me where a particular base will not charge a particular phone.  Once charged elsewhere the problem resolved.
Feb 14, 2008 | Motorola Mobility MD671 Cordless Phone
Lands Phones Logo
282 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
