Whirlpool LSR8444 washer, timer works but no spin or aggitation
I have a whirlpool LSR8444 top load washer, the timer is working but it is not aggitating or spinning?
  • 1 more comment
  • cjohnson426 Jul 27, 2009
    thank you for responding, yes the water comes and goes and I hear motor sound and it does seem slightly louder. Don't normally hang around to listen to it to know what is normal. I got it apart but don't see a belt.
  • cjohnson426 Jul 30, 2009
    You nailed it! Thank you for your assistance. The store where I bought the part said they sell a lot of that part.
    Thanks again
  • steve
    steve May 11, 2010
    Do you hear motor sounds? Will it fill with water? Will it pump out the water?
  • Washing Mach... Master
  • 3,361 Answers
Your problem is a broken drive coupling between the motor and transmission. Replace the drive coupling.
Posted on Jul 28, 2009
    Scholar:
  • 86 Answers
There is a protection feature on the lid (a button/switch) that prevents the washer from spinning/ when the lid is open. When the lid closes, it resumes spinning. It could be the switch.
If you look at the lid there is a prong that goes through a little hole at the top of the washer (where you load the washer) if you run your finger underneath that hole, you will feel the switch. Carefully push the switch, back/forth/side to side and see if it start spinning for you. (KEEP YOUR FINGERS AWAY FROM THE BARREL IN CASE IT DOES START SPINNING AGAIN). If so, the switch needs to be replaced.
Posted on Jul 27, 2009
Washer quit aggitating and spinning when we tipped
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the problem points to the Timer, or the Lid Switch.
Newer model Kenmore Washers use the Lid Switch as a safety device for both the agitate and spin cycles. Older models only used it for the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
Nov 30, 2009 | Kenmore 24902 Top Load Washer
Will not agitate 110 92587210 Kenmore Washer
I have 2 words for you: "dog ears".
the dog aggitation ears are what cause the aggitator to aggitate. Those things wear down and not grab after time.
Pretty easy to change out. You just need to pull the aggitator out and change the 4 little plastic ears. Good luck :)
Jul 13, 2009 | Kenmore 24032\24036 Top Load Washer
Tub will not spin.
Replace the direct drive doupling on the motor.
This video explains how.
Mar 31, 2009 | Whirlpool WET3300S Top Load Stacked Washer...
Washer won't aggitate or spin.
your water pressure tube is clogged at the tub. Take the back of the control panel off and blow or a small balst of compressed air down this tube and try the washer again. Powder detergent clogs this tube at the bottom of the tub and does not tell your pressure switch to shut the water off at the proper level thus overflowing your tub.
Feb 01, 2009 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool LSN1000kq (direct drive) will not spin.
Hi!!! you seem to have a trasmission problem..to expensive too repair unless you have a warranty for it..good luck..
Jan 04, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Aggitates but does not spin out to rinse
From the description of your complaint, I would replace the timer to correct the malfunction.
May 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Drum doesn't pin Model LAT8234AAE
It possibly the switch timer is defective.
Feb 24, 2008 | Maytag PAV2300 Top Load Washer
Whirlpool Washer wont spin or drain
check your lid switch. if it will aggitate and not spin or drain.. then your lid switch is your answer
Oct 29, 2007 | Whirlpool LSR5132PQ Top Load Washer
Washing Machines Logo
169 people viewed this question
Top Washing Machines Experts
