Question about Sub-Zero 632 / S
632 sub 0 and not making ice
0 ice
have reset gage many times. water tube feels a little frozen. could ice in the water tube in the feezer be clogging the machine from working and if so how do I defrost?
  • 631 Answers
The only way is to take a hair dryer and try and defrost it. Sometimes that works and sometimes it doesn't depending on how frozen it is. Just be careful not to melt the line.
Posted on Jul 28, 2009
Sub Zero model 632 Icemaker shutoff arm stuck in the up position. No water in ice tray. Tried turning frig off for 30 seconds, no luck. Checked water supply, it's good. Metal fill tube not...
The shut off arm is in up position. This is the off position for the ice make. Try pulling the down to the first level this will engage the micro switch to start the ice maker. Also, behind the ice maker is a 4 wire plug remove the plug and see if there were some electrical arcing. But first before removing the ice make plug--Please unplug the refrigerator first before work on the ice maker. stewbison
Aug 20, 2011 | Sub-Zero 632 / S
Subzero 632 no water in ice maker ,water supply fine to fill valve,how do you ck valve?
you can check continuity of the valve coil or cycle the icemaker. check the fill tube to the icemaker and make sure it's not filled with ice.
May 22, 2010 | Sub-Zero 632 / S
Water leaks into ice maker bin
2 possible causes. 1) tehe tube is not inside of the ice maker. 2)the ice maker has acrack. better to call a tech
Mar 13, 2010 | Sub-Zero 632 / S
Ice in the bin on subzero 632 freezer is in clumps
if the ice maker leaking it's easy to replace, or may be just a water supply tube has been moved to the side
Oct 03, 2009 | Sub-Zero 632 / S
Ice maker will not make ice
Water fill tube above I/M is probably frozen up. Remove I/M and see. If so, use spray bottle to melt out ice. Unplug and replug in ref when done to reset ice level sensor or it still won't work. If no ice blockage then I/M is bad and needs replacing.
Nov 28, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker line frozen
Use a hair dryer to defrost the tube. It is probably frozen because a leaking water valve. There is also a kit to to add a heater kit to some models. FOr more information call the factory at 800-222-7820.
Oct 02, 2008 | Sub-Zero 632 / S
Sub Zero 632 leaking water
Had the same problem on the same model (632). Turned out to be a plugged drain tube on the condensate collection trough located on back wall of the refrigerator. Simply pull out the crisper drawer (the drawer below the lowest shelf) and you'll bee the trough. The drip tube can easily be plugged by a vegetable leak or grape, etc which had fallen into this trough. Hope its as simple for you as for us.
Sep 30, 2008 | Sub-Zero 632 / S
Samsung Ice Maker on Mdl RB215LASH
It is quite possible the water line near the ice-maker is frozen. I would try a warm hair drier to thaw it out.
Apr 21, 2008 | Samsung RB215LASH
Sub-zero 632 error code 24
clean out auger bucket ec-24 is defrost underheat,to clear press and hold bell on/off key for 15 seconds.
ALL APPLIANCE REPAIR L.L.C
HOT SPRINGS
Feb 28, 2008 | Sub-Zero 632 / S
Sub zero 532 ice maker
When my repair tech came out, he showed me that the fill tube sometimes retracts toward the rear of the freezer. He simply pulled it forward with a pair of needle nose pliers until it rested in the delivery reservoir. This placement allows the detector to know when the tray is full and shut off; thus not overfilling the freezing tray and/or splashing additional water onto the freezer wall and into the ice cube drawer.
Nov 21, 2007 | Sub-Zero 632 / S
Sub-Zero 632 / S Logo
161 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
