Question about Canon PowerShot A520 Digital Camera
E18 Ive had this camera for about 4 years. I dropped it a few days ago and it only works every so often. the lens is now stuck out and the code e18 shows up when i press the power button... is there an answer to this???
    Brigadier General:
  • 4,090 Answers
Absolutely! discard it and buy a new one. The cost of repair excfeeds its value
Posted on Jul 27, 2009
WHEN I OPEN MY CAMERA THERE IS A WORD E18.
Canon E18 error shows when the lens gets stuck while trying to extend.
  • This error indicate that focusing ring got stuck or jammed due sand, dust, may be due to external shock caused by dropping the device. try compressed air. With a fine tip blow off gun around lens barrel. It should remove all dust and sand. Turn the camera on this will solve the problem.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move once or twice then it will stuck again.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Thanks and have a nice day
Jul 04, 2011 | Canon PowerShot A470 Digital Camera
I have a PowerShot S2 IS Icannot take a picture screen show E18.
E18 is the standard Canon lens error. The lens gets stuck when extending. If you did not drop it and there are no signs of damage you can check with Canon and try to get the camera repaired under warranty.
If it is not covered here are a few methods to try on your own, at your own risk.
http://www.e18error.com/repair.html
Good Luck,
-WN
Dec 28, 2009 | Canon Cameras
E18 on canon sd450
the gears might be damaged already for the lens that why its not moving anymore, you may need to contact the manufacturer for service center referral
Jul 25, 2009 | Canon IXUS V2 Digital Camera
My camera is a Powershot A80. Error E18? What does this mean?
Dear Cheuer,
Canon Powershot's error E18 has to do with the lens:
If it appears on a black LCD with E18 written on the corner, it is mostly due to the lens getting stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off or it may not even powe on.
I am giving below a link which will help you with E18 problem.
Hope this helps, let me know if you have a problem.
You can also try the following ;
1). Remove the batteries from the camera, wait a few minutes. Put a fully charged batteries back in and turn the camera on. if it doesnot work then,
Remove the batteries again, as also remove the memory card. Then install the newly charged batteries, when you turn it, hopefully, it should come back to life.
If still you have a problem, then
2). Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during start up. This extra power can be useful to overcome any grit or sand particles that may be jamming the lens.
3). If it is still stuck, please do ensure that you use fully charged batteries, now place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
If Still it does not start, try to
4). Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum
5). Repeatedly tap the padded/rubber usb cover with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. Dont hit very hard please. you might damamge something else
The last solution is if you are good with small screws, then you could open and clean the lens barrel. I can guide you on that, but if you are hesitant then please go to the nearest Canon Service center.
Try the above and let me if its any help.
Please do rate and thanks for using FixYa and Best fo luck to get you camera out of E18
Mar 10, 2009 | Canon PowerShot A75 Digital Camera
E18 error on canon digital camera s200 powershot dropped it and now the lens is stuck halfway out/in The lens will not open, it was not dropped. I get e18 error.
If it appears on a black LCD with E18 written on the corner, it is mostly due to the lens getting stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
Hope this helps, let me know if you have a proble.
You can Try the following also;
2: Remove the batteries again, as also remove the memory card. Then install the newly charged batteries, when you turn it on it should come back to life.
3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during start up. This extra power can be useful to overcome any grit or sand particles that may be jamming the lens.
4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Please do rate and thanks for using FixYa and Best fo luck to get you camera out of E18!
Mar 07, 2009 | Canon PowerShot S200 / IXUS 178 Digital...
E18 Error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try. If there's any consolation, the A400 lens barrel is very resilient in its design, so there is some hope here:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 11, 2009 | Canon PowerShot A400 Digital Camera
Cannon A70 lens stuck in middle causing it to keep powering off
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but if the camera is out of warranty they're worth a try:
May 06, 2008 | Canon PowerShot A70 Digital Camera
Lens is stuck
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
Feb 03, 2008 | Kodak Easyshare M753 Digital Camera
LENS STUCK IN EXTENDED POSTION
Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
Nov 17, 2007 | Canon PowerShot A70 Digital Camera
Unuseable Camera
I had the same prob. on my wife's birthday so I was tearing my hair out to get pics of cards, balloons etc. Then read a (laughable)suggestion that it can be fixed (E18). It was to tap the bottom of the camera hard with the batteries ejected. It worked! So thank you to the correspondent that sent in that tip and saved me a lot of money.
Aug 31, 2005 | Canon PowerShot SD110 / IXUS IIs Digital...
Canon PowerShot A520 Digital Camera Logo
91 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
