Greetings, I read your question and I think Reliable-Store can help you in this. Here's the site link -
Best Manuals
SOURCE: battery drains with mower key in the off position
how long does it take to drain battery,check to make sure battery is good,no bad cells,hold load after charge,check to make sure electric clutch is not staying engaged with switch off...
SOURCE: 19 hp kawasaki mower motor that dies after operating 45 minutes
well its back to the fule flow,,,i thing the fule lines and carb are blocked up and needs a strip down and a good clean up of all the jets and flote bole this sounds like fule shortage,,,if the engine is only just turning and you try to put it in gear so the cutters start to turn it loads the engine up and it stops!
you say pulling the choke out get it going!!!!! then its short of fule ,,,right!
SOURCE: I am working on a
This sounds like a main jet issue. What is a concern is I presume it was okay, before, so that would mean jet restrictions....
Try turning main jet richer or leaner by 1/4 turn and test again...Otherwise, carb surgery will be needed.
SOURCE: My scag mower won't run and spark plugs are not firing
unplug the harness and crank it over see if there is spark then is yes check the safety switches if not check the coils
