Canon MP600 reports it can't print because no paper is loaded. After loading paper we press OK as instructed but the paper is not feed into the printer. No printing occurs
    President:
  • 1,447 Answers
Please select your copier paper tray
then print key press
Posted on Aug 04, 2009
My Canon Pixma MP600R insists that paper is jamed in machine, despite the fact that jam has been cleared and paper is being ejected when machine is switched on
The simplest thing would be to try unplugging the printer from the power source. Let it rest for 5 - 10 minutes then plug back in to the power supply and see if that resolves the problem.
If not you are going to need to do a thorugh inspection to verify that all paper remnants have been removed.
The following is for the MP600:
Issue: ERROR LCD: The paper is jammed. Clear the paper and press [OK].
Solution: Removing paper jams MP600
Removing Obstructions or Jammed Paper If [Paper output slot - The paper is jammed. Clear the paper and press OK] appears on the LCD, follow this procedure to clear the paper jam Clearing paper jams from the auto sheet feeder (ASF) or paper output slot
Clearing paper jams inside the printer
Clearing credit card-sized or 4" x 6" paper jammed inside the printer
ASF / Paper Output Slot
  1. Turn off the printer.
  2. Remove paper from the ASF.
  3. Gently pull the jammed paper out.
    1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
    2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
      The above illustration shows a PIXMA MP500.
  4. If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
    Note:
    Be careful not to touch the components inside the printer.
  5. Turn on the printer and confirm that the Alarm light is off.
    (If the jammed paper remains in the printer, the paper may be automatically ejected.)
  6. Load paper back into the ASF.
  7. Press to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Paper jams inside the printer
  1. Turn off the printer and disconnect the power cord and USB cable.
  2. Remove the jammed paper slowly using the following procedure.
    1. Open the rear cover to check if the paper is jammed.
    2. Pull out the cassette and check if the paper is jammed inside the cassette area.
    3. Stand the printer with the left side down, holding the document cover.
    4. Press the tabs together and pull the green cover toward you.
    5. Check if the paper is jammed.
      (If you were not doing Duplex printing, you do not have to follow this procedure.)
    6. Close the green cover and place the printer back to a normal position.
  3. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
  4. Load paper back into the ASF or cassette.
  5. Press to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Clearing credit card-sized paper jammed inside the printer
Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
  2. Load the same paper type that is jammed inside the printer in portrait orientation.
  3. Power on the printer.
    The paper stock in the ASF will automatically feed the jammed paper from the printer.
  4. To resume printing, load the paper in portrait orientation.
If 4" x 6" sized paper was loaded in landscape orientation in the cassette and did not eject (exit), please follow this procedure.
  2. Open the rear cover.
  3. Fold in four a piece of letter-sized plain paper.
  4. Push in the folded paper until it hits the jammed paper.
  5. If the jammed paper is visible from inside the printer area, pull it out and proceed to step 7.
  6. If the jammed paper cannot be pulled out, push in the folder paper from the rear so the jammed paper is in between the feed rollers.
  7. Pull out the folded paper and close the rear cover.
  8. Power on the printer and confirm that the Alarm light is off.
    The jammed paper should automatically eject.
  9. To resume printing, load the paper in portrait orientation.
Trust this is helpful.
Dec 10, 2010 | Canon PIXMA MP600 all-In-One InkJet...
My Canon mp600 was printing a photo when the error message "paper jammed" came up. I know the paper is in the machine, though I can't find it.What do you suggest?
You can access Canon online support info here. Enter paper jam as a search, then choose #4 to remove the obstruction.
Also see this:
Issue: Paper is jammed inside the printer
    Note:
  7. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
  5. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks
Nov 17, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Auto head alignment
#1 of 2
Carryout a Manual Print Head Alignment If Possible.
If the results of Automatic Print Head Alignment are not satisfactory, follow the procedure below to perform Manual Print
Head Alignment.
1 Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Cassette.
Important. You cannot print the print head alignment pattern if paper of size other than A4 or Letter is loaded. Be sure to use A4 or Letter-sized plain paper.
2 Open the Paper Output Tray, and then open the Output Tray Extension.
(1) Put your finger in the rounded indent of the Paper Output Tray and open it gently.
(2) Open the Output Tray Extension.
3 Press the Paper Feed Switch to select the paper source where you have loaded paper.
4 Select Settings on the HOME screen.
5 Select Maintenance, then press the OK button.
The Maintenance screen is displayed.
6 Select Manual head align, then press the OK button.
The confirmation screen is displayed.
Note. If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
7 Select Yes, then press the OK button.
8 When the Print Head alignment pattern is printed, select Yes, then press the OK button.
9 Look at the printout. From the patterns, select the most even, least irregular patterns for each column and input their numbers. Press the OK button.
(1) Select a column to input the pattern number.
(2) Use the or button to input the number of the pattern.
(3) Repeat the steps (1) and (2) until you finish inputting all pattern numbers, press the OK button.
Oct 08, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon MP600 will not accept paper we load and print after we press OK as instructef
This may not help everyone that I send it to, but it is worth a try.
I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press
the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer.
The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jul 27, 2009 | Computers & Internet
Canon MP600 all-in-one printer.Out of paper?
Try this:
Go into the driver toolbox under printing preferences and select auto
continuous feed from the paper source dropdown box.
Both trays should be of the same size paper and type for this to work.
Jul 10, 2009 | Canon Pixma MP500 All-In-One InkJet...
Mp600 pixma printer
I'm not sure if you've already checked this, but this was my issue. I, too, would try to print something and it would make a great deal of clunking noise but would then say that there was no paper and told me to load some. I went to the Canon site and before I actually went through the process of cleaning the print roller, I checked the feed switch button on the display panel. It's right below the ON/OFF button and, what do you know, it was set to feed from a paper cassette instead of the back loading tray. I pushed the button and it's now printing fine. I'm sure we must have accidentally hit the button when we were trying to turn the printer on or off quickly. Hope this does the trick! It's always nice when it's something easily fixed!
Aug 30, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Printer won't pull paper into printer
Check the "Feed Switch" button on the control panel (below the ON/OFF button) to be sure the green light at the back of the picture is lit. If not, try pushing the button and then printing again. It worked for me and it was so simple!
Aug 22, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP600 printer - paper feed
Issue: Paper feeds skewed
Solution: Clean The Paper Feed Rollers Using The Operation Panel - MP600
Clean The Paper Feed Rollers Using The Unit's Operation Panel If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit. Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary.
  1. Ensure that the machine is powered on and remove any paper from the auto sheet feeder or the cassette.
  2. Use the <Feed Switch> button to select the paper source where you do the paper feed roller cleaning. Click for here additional information.
  3. Press the <HOME> (A) button.
  4. Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Settings], then press the <OK> button.
  5. Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Maintenance], then press <OK>.
  6. Use the Easy-Scroll Wheel (B) or press the up / down arrow to select [Roller cleaning], then press <OK>.
  7. Use the up / down cursor button to select [Yes], then press the <OK> button. (The paper feed roller cleaning starts.)
  8. To check if the rollers are clean, load a sheet of Letter-sized plain paper in the same paper source you selected in step 2.
  9. Use the Easy-Scroll Wheel (B) or press the up / down arrow to select [Roller cleaning], then press <OK>.
  10. Use the up / down cursor button to select [Yes], then press the <OK> button. (Paper will be fed.)
    Note: If paper is not fed properly, repeat steps 4 through 10 above up to three times.
Paper Source
Press the <Feed Switch> button to switch to toggle between the Automatic Sheet Feed (ASF) or Cassette. The light will come on when the <Feed Switch> is set for that paper source.
ASF
Cassette
Note: When printing from the computer, if paper does not feed from the source you have selected on the operation panel, check Paper Source setting in the printer driver. If the option is not set to 'Paper Feed Switch', paper will feed from the source selected in the driver.
Click here to return to step 2
May 31, 2008 | Canon PIXMA MP600 all-In-One InkJet...
35 people viewed this question
k24674
jasbo
jasbo
