Question about Amana Washing Machines
As soon as the water begins to fill into the machine it leaks it all out, and the spin cycle is very noisy, the hoses aren't leaking going into the machine, it seems to leak mostly out of the back, but also from the front, and it seems to rotate slower during the wash cycle. The clothes come out smelling like they are dirtier than when they went in, but the clothes are the usual amount spun (not sopping wet).
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 12 Answers
You need new seal
Posted on Jul 31, 2009
Water leaking from bottom of machine when water is going into the load
I suspect that the hose reaching from the water control solenoids to the fill spout is loose or damaged.
Aug 04, 2014 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
Aug 26, 2011 | Maytag Washing Machines
Hi, we have an F & P GWL11 with a water leak. Have checked all the basic stuff. Hoses, Inlet solenoid etc. No obvious leaks. Tipped machine over and checked and cannot find source of leak. There is a...
Hi Alan.Just read your posting.Now the water on the lip of the cabinet when the machine is laying on its side is from the tank so this will not be the leak.This water on the lip happens every time I tip a machine over on its side.If you have checked the inlet hoses and the black drain hose (when the machine is draining the water) and the inlet solenoids (by removing the top panel and viewing them fill) then I think the only other place is your main tank seal is faulty.Try a wash cycle and after the machine has finished its cycle the look under the machine by leaning it up against the back wall and look towards the center.You will see a round bowl that is colored gray.This is your motor.Now with a torch see if there is any water on it or around it.This should tell you if it is leaking throe the main seal.Has you machine been noisy on the spin cycle?Please reply with additional information on the water on the motor (if any) and whether you have checked all the hoses and solenoids as described.Looking forward to your reply.
Oct 05, 2010 | Fisher and Paykel GWL11 Top Load Washer
Water laks on fill up cycle
Sounds like the rubber fill hose that attaches to the outer tub in the machine has become unhooked. The water from either hot or cold won't make any difference.. it's the hose that actually attaches to the tub. This is fairly common if the machine has been filled to max capacity and during a spin cycle an article of clothing can spin past the hose and knock it out of it's intended location.
You'll need to open the manchine and check the rubber flange on the hose, if it's not damaged you can simply reinstall into the tub. Otherwise, a simple swap out of the hose will get the problem solved.. diagrams are available at repairclinic.com
May 20, 2010 | Kenmore 24032\24036 Top Load Washer
I have a top-load washer that began leaking at the front of the unit. The water is dripping from the front-center of the machine. It begins leaking immediately upon filling and will continue to leak for...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Check the area for the motor and pump.
If you've checked the hoses to and from the pump the problem points to either the pump itself or to the Centerpost gasket.
Neither of these is too difficult to replace, the Gasket requires removing most parts of the washer although the pump is an easy replacement.
Sep 23, 2009 | Kenmore Washing Machines
Leak with heavy load
Is the machne noisy? If not, it may soon become noisy. Sounds as if the grease seal protecting the basket spindle bearings is leaking. soon the bearings will fail
Sep 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Amana washer model LW6501W2 leaks in front during fill up
It leaks Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Apr 01, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
I have purchased a Maytag washer mtw6300tqo and it leaked from the first day it arrived. It does not leak DURING the cycles but leaks profusely a few hours later. I have had service techs look at it and...
Is there water inside the tub after it starts leaking? If so the valve that lets the water into the machine could have a bad seal and overfilling the machine with water when it is not being used. Or one of your water hose seals could be leaking. Make sure the hoses are tight. Beyond that there is nothing to cause a profuse amount of water when the machine is not being used.
Apr 26, 2008 | Maytag Dependable Care LAT9206
Water leaks (drips ) into tub after cycle/spin is complete
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water when is filling only, check the following: 1.Fill hoses
2.The water mixing valve
3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the following:
1.The pump
2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the following:
1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses
5.The stem & seal
Feb 10, 2008 | Maytag LAT2300 Top Load Washer
Open Questions:
Washing Machines Logo
113 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
