Question about TruTech PLV16260 Television
It has audio but no video. i pulled the back light controller and there is a white power around the solder joints.
    Champion:
  • 367 Answers
Any luck?Please let me know.Thank You very much!
Tyler
Posted on Oct 07, 2009
Found a Vizio VO42L By the dumpster and want to try and repair it. I plug it in and the orange logo lights up, press power and it turns on and the logo lights up white but picture flickers with horion
Sounds like it might be a solder joint. use the meter and check the ohms on each side of the solder joints on the board where the serial cables connect to the boards. it would be a good idea to check as many joints as you have time to. If it is a LED TV check Led control board for bad joints. if it uses Flourocarbon tubes check the transisters on each lighting control board. you may only have one board working causing partial back lighting.
Jul 29, 2014 | Vizio VO42L 42 in. LCD TV
My tv starting fading out a couple months ago. I can see some of the picture, but it doesn't fill the whole tv screen. Can it be fixed?
Yes,now turn on the tv started fading out with white lines on the tv CRT-(tv tube) wright?Tv still have audio sound wright?Tv set have cold soldering joints on it tv video board socket holes joints back of the tv video board connections between CRT-(tv tube) and the tv video board.U have some tools like a soldering iron and a role of solders and u can do basic soldering work wright?Take the tv aparts and resolders the back of the tv sockets holes joints of the tv video boad for a good connections between video boad and CRT-(tv tube).Or take to the tvs shops tell them this,if they're not try to cheat u they charges u like $30-35 take the tv aparts and resolders the tv video board back sockets holes connetions joints between the tv video board and CRT-(tv tube) for u.The whole jobs don't take more than 20-25 mins.
Aug 31, 2011 | TruTech T2000FT TV
Hi my name is jeremy snow and i have recently had problems with my sony trinitron xbr 1997. lately the picture like scrunches up into the top of the screen and the tv just goes black and now like sometimes...
This is typical with many sets when it goes old as there is a high possibility that the components over a period of heating and cooling , tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs.
Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points. Please find below a links for tips on poor start ups.
http://www.fixya.com/support/r6055091-slow_start_up_circuit_cold_starting
It is possible you need to check the soldering at the deflection circuits/audio sections as the picture/sound comes back due loose joints which contacts when the circuit is lifted. Solder all the suspected joints with a good light to assist and make sure there are not solder bridges.
Feb 05, 2011 | Sony Televison & Video
Str-de685 WHEN I POWERED I HEARD A CLICK BUT EVERYTHING OFF NO LIGHT.I CHECK BOTH FUSES AND ARE OK.
There is a relay on the power supply circuit board that might be faulty or has bad solder connections. If this relay does not work, power is not applied and everything is "dead". I had to re-solder the speaker relays on my STR-DE675 because they had cracked solder joints which made them work intermittently. It's possible that the power relay is what is causing your problems. If it has bad solder joints it might click, but power might not be able to pass trough the joints.
Does it still click when you turn it on or did it only do this once?
Dec 01, 2010 | Sony STR-DE675 Receiver
MPC T2300. Will not POST.
soldering anything on a laptop Mother Board is risky: overheating, solder spilling over to other connections..... Check around the solder Joint with a magnifying Glass...use a Desoldering tool to remove excess solder
Aug 19, 2009 | Computers & Internet
The A/c does not work in the rear.I have a 1996 nissan quest
you have a bad solder joint in your heater control head. If you can solder, you can fix it. I will fix it for $25 and send you a control head. Then you send yours back to me.
Here's our Villager/Quest web site.
http://groups.yahoo.com/group/villagerquest/links
You have to remove 4 plastic screws on console bottom. Then remove 2 screws at bottom of center trim panel. Then remove ash tray and 2 screws just above tray opening. Then 2 screws at top of center trim panel. Then pull off center trim panel. It has 2 spring clips in center.
Then remove 4 screws holding control head in.
Remove all electrical connectors.
remove thin plastic cover on bottom of unit. 2 plastic clips hold it on.
remove circuit board, and look on back side for crack around solder joint that is circled in red on picture. Or the joint next to it.
resolder the cracked joint. Don't heat the joint too much. Just enough to get solder to drop on to it.
Jun 29, 2009 | 1996 Nissan Quest
Sony wega hdtv
Sounds like a bad solder joint in the power supply or if your audio stays when you lose the video its probably in the deflection circuit either vertical or horizontal. Check the yoke connections.pins for cracked solder as well as the vertical and horizontal outputs also around the flyback.
Jan 21, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Mitsubishi VS-60111 video blink
I would check for Bad solder joints around the flyback, and the verticle and horizontal yoke plugs for starters. Lower your volume and listen if you hear the high voltage come back up when your video comes back up. Let me know what you discover when you check the solder joints.
Jan 05, 2008 | Mitsubishi VS-60111 60" Rear Projection...
Ps2 slim's red light wont turn on (wont run games too)
I have the same problem. At first if I wiggled the powere supply cord, and pulled it in one direction, it worked. After a while it wouldn't turn on at all. I ordered another supply cord, but no luck. I opened up the PS2 to see if I could see anything. The male terminal which the power supply plugs into, has three solder joints on the bottom of the terminal. Mine had the main solder joint broke loose. I am going to try resoldering it back on. I will post again if it works. If not will probably just buy another one.
May 02, 2007 | Sony PlayStation 2 Slimline Console
TruTech PLV16260 Television Logo
60 people viewed this question
Top TruTech Televison & Video Experts
Radames Pagan
Radames Pagan
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
